AKghandi Posted October 19, 2013 Share Posted October 19, 2013 (edited) like the title says, where is it whats it look like? I converted to a manual rack in my lifted 87 gl-10 and there is about 3-4 degrees movement in the steering wheel, the tie rod ends are good, and were recently replaced. the rack mount bushings are also in good shape. the rack itself looks like it was replaced fairly recently, I wiped it off and it looks almost new. I'm sure theres something about it in my haynes or chilton but I haven't seen either book in quite sometime. I did a search but I came up empty handed.. Thanks for the help, if it matters the rack is from an 85/86. If someone has the info floating around( which I'm sure they do). I'll see about getting it added to the USRM. Edited October 19, 2013 by AKghandi Quote Link to comment Share on other sites More sharing options...
skishop69 Posted October 19, 2013 Share Posted October 19, 2013 To my knowledge, there is no pre-load adjustment on any rack unit, just regular steering boxes. I found nothing in my manual suggesting otherwise. 3-4 degrees is nothing to worry about. The manual racks are different internally than the power, so the free play is more noticeable. Quote Link to comment Share on other sites More sharing options...
AKghandi Posted October 19, 2013 Author Share Posted October 19, 2013 its just irritating more than anything because everything else is tight and feels like new except the dang steering. I'm going to look into the linkage in a while and make sure I didn't mess anything up there. I could have sworn i read there was a slack adjuster on these racks. i could be wrong though. I do frequent quite a few auto forums... Quote Link to comment Share on other sites More sharing options...
81EA81 Posted October 19, 2013 Share Posted October 19, 2013 Could it be an inner tie rod causing unseen play Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 19, 2013 Share Posted October 19, 2013 Front of the rack, right on the other side of were the steering shaft comes in. there is a large, thin, flat locknut (36mm, 40mm?) and in the center is a 14mm head bolt. Loosen the lockring, tighen the 14mm bolt in the center, and then tighten locknut. You may need to drop the rack down a bit to unlock the large nut. Quote Link to comment Share on other sites More sharing options...
AKghandi Posted October 19, 2013 Author Share Posted October 19, 2013 Front of the rack, right on the other side of were the steering shaft comes in. there is a large, thin, flat locknut (36mm, 40mm?) and in the center is a 14mm head bolt. Loosen the lockring, tighen the 14mm bolt in the center, and then tighten locknut. You may need to drop the rack down a bit to unlock the large nut. AHA! i saw that 14 mm but i did not see the 36 mm lock nut. makes sense thank you sir! Quote Link to comment Share on other sites More sharing options...
