DangerDussault Posted October 20, 2013 Share Posted October 20, 2013 So the idle on my car has become very irregular, at first it just sat at about 100rpm and I tried using the idle adjustments but they had no effect And my should be right I just checked right before this started Now though all of it sudden it idles at between 6-900 rpm just constantly going up and down up and down, if I give it a little throttle it smoothes out and sounds find but will try to die unless I back off very slowly. One of my friends said to check out the idle air control valve but I can't find it, so anyone have suggestions? Link to comment Share on other sites More sharing options...
MilesFox Posted October 20, 2013 Share Posted October 20, 2013 The iac is the module on top of the thermostat housing with the large hose coming form it which goes under the '4wd turbo' plenum Try removing the hose and [lugging it by hand or pinching it down with a pair of nickels and a vise grip and see if this changes the idling Link to comment Share on other sites More sharing options...
DangerDussault Posted October 20, 2013 Author Share Posted October 20, 2013 Any idea where I can get a new one? I've been looking but no luck Link to comment Share on other sites More sharing options...
czny Posted October 21, 2013 Share Posted October 21, 2013 (edited) Had to resort to buying a new one last year: https://www.rockauto.com/catalog/x,carcode,1268513,parttype,6072 Pricey! Hadn't found a good condition IAC at the PAPs in months & believe me I'd tried a few used ones. Had to meet emissions for Peoples Rebublic of California & mine wouldn't idle steady either. edit: sorry, re-read your post. RX model. Edited October 21, 2013 by czny Link to comment Share on other sites More sharing options...
DangerDussault Posted October 23, 2013 Author Share Posted October 23, 2013 This looks nothing like the part I have Link to comment Share on other sites More sharing options...
jono Posted October 23, 2013 Share Posted October 23, 2013 half inch ID heater hose does the immediate trick for the hose that carries air between the thermostat gadget and inlet manifold of an EA82 mpfi turbo inlet. I actually have mine blocked off with rubber water caps, just control fast idle by foot when cold. Link to comment Share on other sites More sharing options...
czny Posted October 23, 2013 Share Posted October 23, 2013 (edited) This looks nothing like the part I have Yeah, I realized that after posting. There have been fewer & fewer GLs, no RXs since about 5 yrs ago down here at the local PAP. I'll watch for a turbo when I go there if that helps. Check this out: http://www.ultimatesubaru.org/forum/topic/141509-new-junk-yard-found/ Edited October 23, 2013 by czny Link to comment Share on other sites More sharing options...
DangerDussault Posted October 23, 2013 Author Share Posted October 23, 2013 Okay sweet I live close by to that place I'll check it out thanks for your help everyone Link to comment Share on other sites More sharing options...
naru Posted October 23, 2013 Share Posted October 23, 2013 It won`t be the AAV. They are easy to check.Undo it and note the position of the rotary vane hot/cold. Sounds more like a vacuum or unmetered air leak. Link to comment Share on other sites More sharing options...
mr sarcastic Posted October 23, 2013 Share Posted October 23, 2013 Ya, I agree with naru. The aav is an open/close unit. Closed it will give you your lowest idle and this is the possition it in most of the time. It's only open when cold, and open it raises the idle. If your aav is malfunctioning, chances are you'll have low idle on cold starts ONLY, or a high idle once the car is warmed up. Link to comment Share on other sites More sharing options...
