hackasubaru Posted October 21, 2013 Share Posted October 21, 2013 Hello All, So I've finally finished my EJ swap on my GL wagon.. finally.. I'm just now setting up my gauges and had a question about the tachometer. I'm wondering what wire to tap into on the cluster plug of the EA harness? The cluster wiring is still in place on the EJ harness so I just need to know which color is the tach wire on the legacy cluster(from the ECU to the dash plug) and which color is the loyale tach(dash plug)? I included a few pictures to help with explaining. I thought it was probably easier posting on here then sorting through my mess of printed out factory manual pages.. EJ harness wires going to cluster plug on the "legacy" harness. I'm pretty sure its one of these three just don't remember which one: And here is the cluster plug wires on the loyal car: And just because I'm so happy its done! Under the hood... Thanks in advance 2 Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 21, 2013 Share Posted October 21, 2013 I think you need to have a better look at the instrument cluster and learn how circuit boards work. The pics you've posted for the cluster are not for the gauges... Also, there will be some stamping on one of the "tracks" behind where the tacho goes saying "Tach". Trace it along the board... Quote Link to comment Share on other sites More sharing options...
hackasubaru Posted October 21, 2013 Author Share Posted October 21, 2013 Really? Because I'm pretty sure I understand circuit boards. I already looked for the "stamping" on one of the "tracks" as you say. I didn't see it in plain view. It's probably there; I just didn't spend alot of time looking yesterday. I understand "tracing it along the board" would lead me to the correct wire... I ran out of time and thought I'd post because someone would know off the top of their head. I had guessed it might be these two plugs on the EA car because it was similar to the legacy I pulled the harness from. I now know which wire to use from my first/second picture... Black/Blue - Tachometer Green/White - Oil pressure light White/Green - Collant temp gauge Just need to know the wire on the cluster for the EA car.. any takers? I'll figure it out later when I get home... again.. just thought someone might know off hand. Quote Link to comment Share on other sites More sharing options...
hackasubaru Posted October 22, 2013 Author Share Posted October 22, 2013 Finished soldering some wires. Tachometer is working now. Round black plug on cluster - yellow wire. Just needed the service manuals for the loyale to confirm which one it was. JD was kind enough to host them: http://jdfinley.com/file-downloads/subaru-manuals/ FYI - there is no "stamping" on one of the "tracks" that says "Tach". So actually having it pulled out and in front of me... I can confirm that. I've traced plenty of wires mapping out keyboards, mother boards, printer PCB's, etc... It's kinda what I do for money. I picked some plugs, assumed, took pictures and posted because it was late and had work the next morning. Good to go now. Quote Link to comment Share on other sites More sharing options...
Lou Baroo Posted October 22, 2013 Share Posted October 22, 2013 That looks nice! Congrats! 1 Quote Link to comment Share on other sites More sharing options...
ivans imports Posted October 22, 2013 Share Posted October 22, 2013 Black wire with blue stripe on legacy and soilid yellow on gl i jion my tach wires by were the loyale coil was mounted 1 Quote Link to comment Share on other sites More sharing options...
hackasubaru Posted October 22, 2013 Author Share Posted October 22, 2013 (edited) thanks guys! Got it all figured out last night Edited October 22, 2013 by hackasubaru Quote Link to comment Share on other sites More sharing options...
el_freddo Posted October 23, 2013 Share Posted October 23, 2013 (edited) For my temp gauge and oil pressure warning light I just hooked up the EA wire at the engine to the EJ sensor. I really need to get around to doing the resistor mod on the temp sensor to make my temp gauge more "factory active"!And for the Tacho, I picked up the yellow wire behind the big plugs for the dash board above the driver's feet - this way I don't need to worry about the EJ wires when I remove the dash board - it's all still a plug and play setup without complications EJ's look (and go) awesome in the L series! EnJoy! Cheers Bennie Edited October 23, 2013 by el_freddo Quote Link to comment Share on other sites More sharing options...
