Luvn737s Posted October 22, 2013 Share Posted October 22, 2013 I pulled the heads on my 85 GL rebuild and the lower head bolts came out covered in a black sooty oily gunk. The upper 2 were clean as a whistle. Ideas? Advice? Sympathy? Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2013 Share Posted October 23, 2013 that's about normal. wire wheel them, parts cleaner, give them to a machine shop for their parts cleaner. annoying. Link to comment Share on other sites More sharing options...
Luvn737s Posted October 23, 2013 Author Share Posted October 23, 2013 How does gunk get into the bolt hole, other than a crack from the exhaust port? Link to comment Share on other sites More sharing options...
pressingonward Posted October 23, 2013 Share Posted October 23, 2013 That nasty black tar that smells horrible is engine oil that seeps in past the bolt head and bakes in there for a few decades. It's completely normal. Link to comment Share on other sites More sharing options...
MilesFox Posted October 23, 2013 Share Posted October 23, 2013 The heads bolts thread thru coolant and oil passages. the fluids capillary actoin up the threads. How foul the bolts are are conducive to the location of each one. Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2013 Share Posted October 23, 2013 other than a crack from the exhaust port? it's definitely not that, looks like miles has it covered, it's normal. Link to comment Share on other sites More sharing options...
MilesFox Posted October 23, 2013 Share Posted October 23, 2013 One could use anaerobic on the threads to seal it out. This would be a good idea for intake manifold bolts since they rust. So would be regular coolant and oil changes to prevent corrosion and varnitsh Link to comment Share on other sites More sharing options...
Luvn737s Posted October 27, 2013 Author Share Posted October 27, 2013 Yeah, all the good advice here was repeated by the machine shop. There was some light pitting after running them across the wire wheel, but I feel pretty confident about reusing the ones with perfect threads. Would just about any metric thread chasers work to clean the case threads before reassembly? Link to comment Share on other sites More sharing options...
BoxerRebellion Posted October 27, 2013 Share Posted October 27, 2013 (edited) Gravity. If I were you, I'd use a degreaser (kerosene being the cheapest) and a brass brush. Brass, as an extra assurance not to damage threads. Edited October 27, 2013 by BoxerRebellion Link to comment Share on other sites More sharing options...
Gloyale Posted October 27, 2013 Share Posted October 27, 2013 Would just about any metric thread chasers work to clean the case threads before reassembly? Nope. M11 x1.25 Very hard size and pitch to find taps and die for. Not impossible.......but very hard. I gave up just used an old bolt and cut grooves long ways down the side to make a block chaser. Got any spare bolts??? Link to comment Share on other sites More sharing options...
czny Posted October 28, 2013 Share Posted October 28, 2013 use-enco.com for M11-1.25 tap: http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=891-4976&PMPXNO=3904809 Link to comment Share on other sites More sharing options...
MilesFox Posted October 28, 2013 Share Posted October 28, 2013 If all fails, oil the bolt and run it in and out of the threads, wipe it off, and assemble. Link to comment Share on other sites More sharing options...
Luvn737s Posted November 3, 2013 Author Share Posted November 3, 2013 KEEP 'EM STRAIGHT!! I just finished a complete cleanup of the headbolts, oil and end-seal, replace the headgaskets and torque nicely. Only to find out I swapped the heads to the wrong side! I am so P----ed!! New head gaskets ordered. 1 week delay. Link to comment Share on other sites More sharing options...
MilesFox Posted November 3, 2013 Share Posted November 3, 2013 you can make it work. i had the luxury of working on one with reversed heads. It had a copper pipe across the top for the EGR. Link to comment Share on other sites More sharing options...
