gravelRX Posted April 26, 2004 Share Posted April 26, 2004 Well, besides the charge light being on all the time, and the emergency brake indicator glowing dimly, the other weird thing is when I turn on the headlights, the brake fluid indicator comes on. The charge light. I have the correct alt putting out 14.5 tops, and the battery connections are clean on a new battery. I think this is a loose wire as it pulsates to the bumps in the road. the brake fluid indicator light on with the headlights. Would like to see a wiring diagram to see how the headlights and warning lights tie in together. I'm guessing a ground. The radio doesn't have constant power so it forgets all the presets when you turn it off. PITA. Need to know what wire in the engine harness goes to the choke tang on my Weber DGEV. I'm guessing the blue wire. Suggestions?, Jay Link to comment Share on other sites More sharing options...
subiemech85 Posted April 26, 2004 Share Posted April 26, 2004 did the car run with the coil wired backwards? check fuses, fusible links my diagrams in the fsm are pretty sketchy, and are in the car stuck in the mud Link to comment Share on other sites More sharing options...
thealleyboy Posted April 26, 2004 Share Posted April 26, 2004 Jay: I've got the FSM's for your car. Email me off the board, and I'll try to get you the info you need. thealleyboy@yahoo.com John Link to comment Share on other sites More sharing options...
gravelRX Posted April 27, 2004 Author Share Posted April 27, 2004 Yes, the car did run with the coil wires on backwards. Fuses and links are OK, Checked them with a meter. I believe this is going to be a gremlin hunt unless someone has experienced the same problems. John, Emailed you. More suggestions? Thanks, Jay Have replaced wires and plugs with NGK products since the picture was taken and built 2" exhaust from the heads to the oversized cat, then 2 1/2" out the back with a low flow muffler. Link to comment Share on other sites More sharing options...
thealleyboy Posted April 30, 2004 Share Posted April 30, 2004 Jay: There are 2 carb diagrams in the FSM for 85. 2wd and 4wd. I'll mail you photocopies of both. Once you can establish that the wiring is correct, we can deal with the drivability issues. It's going to be tricky because it looks like (judging by the pic) that much of the OEM system is gone. Needless to say, the wrong emissions setup in a car like a mid 80's carberated Sube, will make the car run like sh*t. Fortunately, the basics still apply, and you should be able to make this thing run smooth again. Hopefully, you don't live in a state where registration officials pay close attention to this sort of thing. good luck, John Link to comment Share on other sites More sharing options...
gravelRX Posted April 30, 2004 Author Share Posted April 30, 2004 thanks for the copies. The car actually runs like a top. Bumped the timing up tonight and got rid of the "secondary stumble" when you step down on it. The problem I'm having is with the dash wiring, Funky things. Found another tonight, might be a clue. the rear wiper control switch has correct output current to the motor in the back. The motor on the other hand, never gets the current. If I hit the switch you can hear the belt on the alt and the charge light goes out as long as the wiper switch is on. Hmm. thanks again for the diagrams. Regards, Jay Link to comment Share on other sites More sharing options...
Svengouli7 Posted April 30, 2004 Share Posted April 30, 2004 hi Gravel Pretty sure its the blue wire- in a group of three like this _ l l top wire. Link to comment Share on other sites More sharing options...
gravelRX Posted April 30, 2004 Author Share Posted April 30, 2004 Blue it is, Thanks, Jay Link to comment Share on other sites More sharing options...
