Subarocket Posted October 29, 2013 Share Posted October 29, 2013 Is there a sub forum or site for Canadian ea82 fans? Something for parting out cars, junk yard finds, etc? Link to comment Share on other sites More sharing options...
Beatnic Posted November 5, 2013 Share Posted November 5, 2013 Hi! not sure what an ea 82 is but I have a dead 94 Loyale I am trying to resurrect wont start no spark computer doesnt flash codes- how to make it do so I wonder [ need rad also] ? I am in Nelson area cheers Link to comment Share on other sites More sharing options...
Beatnic Posted November 7, 2013 Share Posted November 7, 2013 UPDATE patched the crashed rad with jb weld , tested it ith air and put it in todayfor when it is running then tried a dist test with light from neg on dist [ blue yel wire] to ground suggested by Cougar: #6 [Loyale - No Spark: post #6] Cougar Posted 01 May 2013 - 07:33 PM JIM do this test:: JIM Those wire colors are correct I think. Using a test light probe check to see if you have light pulses on the minus side of the coil while you crank the engine. If the light is steady ON then there is a possible problem with crank sensor. If there is no light then the coil has an open wire Nov 7 tested it- no light or pulse - change coil Tried it- no light or pulse so if no snow tomorrow will change the dist and try again Link to comment Share on other sites More sharing options...
madmanmike Posted November 7, 2013 Share Posted November 7, 2013 hey Im a soob lover in western canada! sign me up! Link to comment Share on other sites More sharing options...
