Scott in Bellingham Posted October 30, 2013 Share Posted October 30, 2013 Im thinning down a 98 EJ22 harness auto question is , after thinning can I use the grounds on the engine and not ground the harness? and if not which grounds, wire colors would be the ones to hook into for grounds on the harness thanks Guys Link to comment Share on other sites More sharing options...
Gloyale Posted October 30, 2013 Share Posted October 30, 2013 Everything except the Ignition relay and fuel pump relay should tie into the intake ground. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 30, 2013 Author Share Posted October 30, 2013 Everything except the Ignition relay and fuel pump relay should tie into the intake ground. was wonderin about that Link to comment Share on other sites More sharing options...
