^That seems like a fair price for the year and mileage.
More fun last night
looks like they used a helicoil for the TB tensioner so I guess I have to swap that out from my Ej25
Edited by 1-3-2-4
OK I have a question since I haven't seen any talk about it.. has anyone ever used anaerobic sealant on the oil pan? I've only seen people use RTV, but given that it's in the low 30's it's going to take forever for the RTV to cure.
Anaerobic will start curing near immediately. I've bolted the pan on my Saab, filled oil within the hour, and was driving almost right away with ZERO leaks. It isn't dependent on weather or humidity. It ONLY cures in the absence of air. If exposed to air, it'll never cure. I can run my finger on the outside seam and there's still soft 518 there as it never cured since it's squished outside. I've used it on my Saab (it's a requirement) which has the same style oil pump as Subaru. If any gets in the oil, it won't destroy the oil pump like RTV will or other hard sealants as there is still air in the pan. Only what's compressed is without air. ONLY concern is the mating surface MUST be nearly flat with NO gaps. Saab uses an aluminum oil pan, so that really isn't an issue. Steel pans on the other hand can be.
I decided on using the ultra grey RTV, about mid way the friken metal split on the side of the rtv :-/
So I ended up just taking off the nozzle and spreading it on the pan and thinning it out with a razor, pan is on.. had to do a little mod since almost all aftermarket pans don't have the dipstick tube holder angled up high enough so it can go in and still screw the bolt in at the top of the block.
Next is the water pump.. No point in taking the heads off now since as of right now since i plan on installing a oil pressure gauge and I forgot about the oil gallery plug and a oil sensor relocation kit I might push the install and pulling the motor by a few days.. I'm super paranoid at oil pressure at first start up more so then normal since I don't know so much of the history of the motor.
If you have the oil pressure gauge, just thread it into the warning light sensor hole under the back side of the alternator and ignore the dummy light wire for now. I'm running mine like this and leaving the oil pressure light gauge wire unplugged, you just won't get the oil light on with key "ON". It'll stay off indefinitely, but at least you can watch the oil pressure instead which is more helpful. On mine with 10w30 synthetic, the pressure stays high for quite awhile before finally settling around 11-12 psi at 650 rpm idle. Closer to around 14 at 700. Hope you used the RTV sparingly. If any breaks off in the oil it can get in places you don't want it.
Edited by Bushwick
Checked this morning at the RTV is a lot stiffer this morning after getting some freezing rain and snow, and yes I used RTV sparingly I know all about it blocking oil passages, my older sender is 1/8" NPT so it wont fit in the stock oil pressure spot, I'm going to use the oil gallery plug on the back of the motor and remote mount the sender.
i rather wait a few extra days then having to remove a intake manifold that I just installed with new gaskets.
man its cold out today... trying to pull off the intake manifold off the ej25 and bring it inside to prep to paint it, one of the brackets on the passenger side that goes to the plenum came off I ended up giving a friend the rest of my vaccum hose and I went to move a line I did not bother to change and it snapped.. :rolleyes:
Tonight a low of 15F
You do know the EJ25 manifold will not bolt onto the EJ22, right?
You can swap the wiring, and the throttle body if it doens't have the same TPS......onto the EJ22 manifold.....but no need to paint the EJ25 manifold unless you want a piece of livingroom art.
My oil pressure relocation kit came in today.. I think I might be sending in my injectors for a flow test and cleaning.. I told my friend since I have to power coat and wanting to clean up all this while stuff is off just to wait until Jan.
I think it's worth getting the injectors flow tested now that I have 256,000 miles on them, no? At least one of them has a little crud on them but not blocking the nozzle
It'd be like $20 for used with a 1/4 of the mileage. They don't last forever and most likely are hurting performance and economy on some level.
If they pass the flow test then how would they be hurting performance.
Checked Ebay and a used single injector is $25
There were no "new" standard flow injectors for sale at all.  Only 550cc and higher turbo application type.  They aren't new but cleaned, increased flow, and tested.  Who knows what quality guts they "rebuild" them with.......but they range from $300 to $600 dollars and are all waaaaay too big a flow for a N/A engine.
You personally may have some hookup or source for cheap injectors......but you can't give advice to others based on circumstances that are specific to you.
I'd say he's better off testing a known good set of OEM injectors, and using those rather than some "upgrade" rebuild ones.  Certainly cheaper, and OE subaru is almost always higher quality than unknown chinese electronic parts.
You can find inexpensive injectors new ONLINE if you look for them. They also can typically have better fuel atomization which can be very beneficial to the overall operation of the engine and can be just as good quality.  "Siemens Deka" are an example.
I can get used locally for next to nothing like pretty much anyone in the US can. I'll offer advice if I think it'll save somebody some money. If it was a carb with 256k miles, I'd say rebuild or replace depending on rarity and condition. With injectors that have THAT many miles, why throw away $88+ just to hear they'll need cleaned or rebuilt, or have one (or more) that can fail at any moment thereafter, which will add more $$$ to overall cost when it'd been cheaper to just have gone the other route to begin with? Not to mention injectors are NOT serviceable by normal mechanics. He'd be better off running kerosene through it in a stand-alone scenario (out of the car) and eyeing the pattern, googling a known "good" pattern, then going from there. Chances are he'll get scammed and handed back injectors with NOTHING done to them, or get pitched he'll need replacements or "repairs" to them where they'll go and get a junk yard set for $20, throw his away, and give him the bone yard injectors for an inflated price. No idea why you are calling me out on this, but come on.
This topic is now closed to further replies.
