EA81 Sun Visor
The left sun visor on my 87 Brat keeps on flopping down.  I can pull it out a bit and it will hold.  I have tried tightening a screw on the visor and it helps some, but after a few times, the visor becomes loose again and just flops.  New ones are not available anymore.  What are folks doing for replacements?  Any after-market options, or do visors from any newer Subaru's work?
Usually, it becomes loose because the internal clamp breaks...
I've solved that issue in other cars by adding an "External" clamp over the broken one,
it doesn't look good but is not much noticeable, and works flawlessly.
See Photo Here: ~► http://www.ultimatesubaru.org/forum/topic/101718-kia-sephia-sporty/page-8?do=findComment&comment=1120338
Kind Regards.
Try one of those black binder clips around where the clamp is -find the right size/place and put it on, then pull the "legs" off of it. You'll never notice it. Haven't tried this on a subaru,(I'm about to) but it has worked on others. If it doesn't work, well, you're out .05 cents!
