AKghandi Posted November 3, 2013 Share Posted November 3, 2013 2.5" shop vac hose $29, 3" hole saw $16, roll of ductape $8.99, various hose clamps, free. being able to do this; priceless. I'll get a pic of how its routed and hooked up tomorrow. still need to finish water proofing it but its a good start... i think water actually went into the intake side of the snorkle lol. Link to comment Share on other sites More sharing options...
Uberoo Posted November 3, 2013 Share Posted November 3, 2013 Is the ducttape temporary mounting or something? Link to comment Share on other sites More sharing options...
AKghandi Posted November 4, 2013 Author Share Posted November 4, 2013 (edited) its a temporary way of attaching the hose to the carb air box. i have to figure out something more.. air tight. like a carb hat or something I used the hose clamps to mount it. i screwed them on with self taping screws and clamped the hosed down. I put it together in about an hr including the trip to lowes, at about 6 am before i went out wheeling. Edited November 4, 2013 by AKghandi Link to comment Share on other sites More sharing options...
1988subiman Posted November 4, 2013 Share Posted November 4, 2013 We need pictures lol Link to comment Share on other sites More sharing options...
AKghandi Posted November 5, 2013 Author Share Posted November 5, 2013 (edited) Edited November 5, 2013 by AKghandi Link to comment Share on other sites More sharing options...
AKghandi Posted November 5, 2013 Author Share Posted November 5, 2013 I'm open to pointers on how to better waterproof it. this was just a quick and dirty way of getting it to work. Link to comment Share on other sites More sharing options...
Uberoo Posted November 5, 2013 Share Posted November 5, 2013 First off route the tubing up higher in the inner fender,In the short time that has been there it has already gotten some road rash/rubbing from the tire.As for a better solution cut the snout of the airbox off and weld on a piece of tubing that will fit inside your tubing.Then hoseclamp + RTV your flex tube to the airbox. Link to comment Share on other sites More sharing options...
Gloyale Posted November 5, 2013 Share Posted November 5, 2013 On 11/5/2013 at 8:52 AM, Uberoo said: First off route the tubing up higher in the inner fender,In the short time that has been there it has already gotten some road rash/rubbing from the tire.As for a better solution cut the snout of the airbox off and weld on a piece of tubing that will fit inside your tubing.Then hoseclamp + RTV your flex tube to the airbox. Cut off the "warm up" flapper too. That will be an open spot to suck in water when cold (could open suddenly even with warm engine when submerged......underwater does funny things to temp related equipment) Link to comment Share on other sites More sharing options...
AKghandi Posted November 6, 2013 Author Share Posted November 6, 2013 sounds good. I flexed the car pretty seriously and the tire didnt touch. though i am going to tie it up a little higher. I'll have to look into cutting the snout off and welding a pipe on there. i have a welder but my skills are not that good. Link to comment Share on other sites More sharing options...
Uberoo Posted November 6, 2013 Share Posted November 6, 2013 Thats a perfect time to practice on it then.What better than a non structural piece to build your confidence. Link to comment Share on other sites More sharing options...
AKghandi Posted November 7, 2013 Author Share Posted November 7, 2013 On 11/6/2013 at 7:18 PM, Haight said: No filter? Or am I missing something. it has a filter in the air box on top the carb Link to comment Share on other sites More sharing options...
Uberoo Posted November 7, 2013 Share Posted November 7, 2013 On 11/7/2013 at 5:00 PM, Haight said: Oh wow....I feel super smart. Now you know. Link to comment Share on other sites More sharing options...
Uberoo Posted November 7, 2013 Share Posted November 7, 2013 (edited) you might need to work on your hands/brain interface thing.Similar to driving a manual, clutch in, engage brain,clutch out,easy dont stall it or you will back up traffic... my problem on test day my brain is like an old car with a bad carb.I stall it the first question then its like this through the test. http://www.youtube.com/watch?v=TK9kX-n6aBU Edited November 7, 2013 by Uberoo Link to comment Share on other sites More sharing options...
AKghandi Posted November 8, 2013 Author Share Posted November 8, 2013 that would be the sound of a small block chevy. lol.. i would know ive been hearing it alot lately working on my camaro Link to comment Share on other sites More sharing options...
AKghandi Posted November 8, 2013 Author Share Posted November 8, 2013 so after a couple hours of RTV and replacing hoses im finally happy with it. the biggest problem was the lid for the aircleaner wouldnt seal. so i had to put a piece of split hose around the rim. the snorkle actually sucks now... doesnt quite stall the motor but im not %100 sure subarus even need air anyways. Link to comment Share on other sites More sharing options...
akoffroad Posted November 24, 2014 Share Posted November 24, 2014 somebody has been playing at jim creek Link to comment Share on other sites More sharing options...
