Illumi control mod location...
Is the Illumination Control module located behind the glove box or underneath the steering wheel in a '98 outback wagon?
My instrument lights are all out (along with the glove box light) and it makes night driving a little problematic.  I think that the ICM may be the cause....
I checked fuses and they all seem to be intact...
Thanks!
--Damien
Grab a multi-meter and chase it.
Also, on top of simply physically verifying that fuses aren't blown, check them for voltage with the ignition "ON"
That'll start the "chase" then go from there.
Find out what fuse the ICM is on, trace it from there. (I realize, it's a pain)
I don't know for certain regarding it's location, sorry.
There could also potentially be a bad ground somewhere.
Did you install a radio recently?  I had a friend that had a 97 Impreza and they saw power on one of the radio wires so they thought it was hot.  It was really the downstream voltage for all of the dash lights looking for a ground.  Radio and cig, lighter.
Did you accidentally roll the dimmer wheel on the headlight stalk all the way to the off position?
And yes, if someone installed an aftermarket stereo and tried to hook up the dimmer wire, they cooked the Illumination module.
Illumination control module is under the drivers side dash near the steering column. Has a 6 pin black connector.
Edit again, I was looking at the wrong wire diagram.
Your rear lights should be supplied power by fuse 5 in the under-dash fuse panel.
Edited by Fairtax4me
Hey thanks...that's helpful.
No I thought of the obvious...but even with the wheel all the way down it would still be a little lit...right?  :-)
Another thing that doesn't work is when I pull the windshield wiper stalk it engages the wiper motor but not the spray...(it did work sometimes...but only very intermittently).
This makes me think that there could be a corroded contact somewhere in there or something.... :-/
I'm not sure on the newer ones, both my 95 and 96 have a separate button on the end of the stalk for the spray. Pulling the stalk does a single wipe.
Also on both of those, turning the dimmer wheel all the way down turns the dash lights completely off.
Actually a short in the glove box was blowing that very fuse.  When I would open the glove box the fuse would blow.  I think I must have re-inserted the bulb in the socket incorrectly when I took it out to inspect it.
When I took the bulb out and tried it again...the fuse didn't blow.
Wow good timing, somehow my glove box light did the same thing to me one morning as well! I went to work, turned on the lights and I heard a crackle sound and then next thing I know my dash lights went out.. it sucks because I drive to work at 3:30 AM.. and it seems the glove box light has no part number? I looked at it and still can't figure out how it went wrong but it seems a piece of metal might of bridged between the two connections.
  • 4 weeks later...
