pparrish Posted November 4, 2013 Share Posted November 4, 2013 1992 Loyale Drivers side brake light just stopped working. New 1157 bulb; no change. Drivers side tail light and passengers side tail and brake lights work fine. Any ideas? Link to comment Share on other sites More sharing options...
MilesFox Posted November 4, 2013 Share Posted November 4, 2013 wiggle the pigtail connector where the lamp assembly plugs into the body harness. Is it only the brake lamp not working? Is there a trailer hitch wiring setup? Link to comment Share on other sites More sharing options...
pparrish Posted November 4, 2013 Author Share Posted November 4, 2013 Yes, only the brake lamp. No trailer wiring. Thanks Link to comment Share on other sites More sharing options...
MilesFox Posted November 4, 2013 Share Posted November 4, 2013 (edited) I would suspect if the pigtail is not loose or corroded, one of the pins in the socket has either corroded, or came disconnected from behind. Bulb sockets can and do wear out. My eperience working at u-haul, most of the time qa bulb was unresponsive, a wiggle of it in the socket would get it to come back. Sometimes the sockets had to be replaced from wear I would suggest wiggling the bulb or pushing down and turning a little while someone stands on the brake to determine if it is the socket or something else. Edited November 4, 2013 by MilesFox Link to comment Share on other sites More sharing options...
BoxerRebellion Posted November 5, 2013 Share Posted November 5, 2013 Sounds silly, but make sure the bulb is in correctly. Having the offset "side posts" or "terminals" allows for only one proper fit. Link to comment Share on other sites More sharing options...
Gloyale Posted November 5, 2013 Share Posted November 5, 2013 Ground wire stuffs into the socket and is pinned agianst the outside of the metal "barrel" that the bulb fits into. Sometimes they ground wire needs pulled out, cleaned, adn stuffed back in against that barrel. Although....since your tailight works on that side, it's gotta be on the + wire to the brake light. Link to comment Share on other sites More sharing options...
