Scott in Bellingham Posted November 5, 2013 Share Posted November 5, 2013 got my Wheeler going, its runnin a stock EJ22 stock everything, noticed then when wheelin most the slow going is like 100 rpms, is there anyway to get more power down in them low RPMs? maybe somethin with the electronics? I know I can install the Delta cams which ive done on past wheelers , if electrons make a difference would be cool to have a switch on the dash to make the change, any thoughts? Link to comment Share on other sites More sharing options...
MilesFox Posted November 5, 2013 Share Posted November 5, 2013 longer stroke. Link to comment Share on other sites More sharing options...
monstaru Posted November 5, 2013 Share Posted November 5, 2013 Build a Frankenmotor with torque cams. Link to comment Share on other sites More sharing options...
subnz Posted November 5, 2013 Share Posted November 5, 2013 (edited) Unlikely because all subaru boxer engines don't have much mass/inertia below 1500/2000rpm (flywheel etc ) for low down torque because cylinders oppositely opposed they are well balanced no need for it. An alternative is to go to a lower diff ratos if you want to go slower over the rough stuff. (and assuming you already have dual/ratio as well) If you want that sort of idling torque, need to consider a diesel alternative. Edited November 5, 2013 by subnz Link to comment Share on other sites More sharing options...
Turbone Posted November 5, 2013 Share Posted November 5, 2013 Divorced t-case. 2 Link to comment Share on other sites More sharing options...
monstaru Posted November 5, 2013 Share Posted November 5, 2013 Unlikely because all subaru boxer engines don't have much mass/inertia below 1500/2000rpm (flywheel etc ) for low down torque because cylinders oppositely opposed they are well balanced no need for it. An alternative is to go to a lower diff ratos if you want to go slower over the rough stuff. (and assuming you already have dual/ratio as well)The mass of an unlightened flywheel mixed with Delta torque cams makes a lugger. I have had it in front of an automatic, and a 5 spd. Both combinations have given more "power" down low. There is plenty of low RPM usage from these vehicles. We all have been doing it for years. Just because the engine is balanced does not mean it can not "lug" .It actually helps it lug really. lol Link to comment Share on other sites More sharing options...
presslab Posted November 5, 2013 Share Posted November 5, 2013 The only electronic thing I could think of is to advance the timing at low RPM. Could probably advance it a fair amount, especially on high octane. Link to comment Share on other sites More sharing options...
Tsuru Posted November 5, 2013 Share Posted November 5, 2013 Don't forget, it needs to breathe freely, restrictive intakes are death to torque, but by the same token, too open and they won't develop proper cyclic flow and will impede torque development as well. -OR- propane injection... solenoid valves, flex tubing to the intake, flip a switch, power up and go. (its popular here in the Montanas) truthfully I do not know if that even works, to my thinking, it is counterproductive at low RPMs but I know a couple of guys out here who swear by it. (never ridden with them, so I cannot say for certain) and yes, this on on normally aspirated gasoline fueled engines. Although...I hear is a hoot in a diesel! Link to comment Share on other sites More sharing options...
ferox Posted November 5, 2013 Share Posted November 5, 2013 got my Wheeler going, its runnin a stock EJ22 stock everything, noticed then when wheelin most the slow going is like 100 rpms, is there anyway to get more power down in them low RPMs? maybe somethin with the electronics? I know I can install the Delta cams which ive done on past wheelers , if electrons make a difference would be cool to have a switch on the dash to make the change, any thoughts? By electronics do you mean some kind of controller or do you mean an electric motor(s)? Link to comment Share on other sites More sharing options...
Uberoo Posted November 5, 2013 Share Posted November 5, 2013 Supercharger. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 5, 2013 Author Share Posted November 5, 2013 The only electronic thing I could think of is to advance the timing at low RPM. Could probably advance it a fair amount, especially on high octane. how would I go about doing that? seems like you would want to retard the spark for low RPMS like on my Model T Link to comment Share on other sites More sharing options...
presslab Posted November 5, 2013 Share Posted November 5, 2013 Low RPM is more retarded compared to higher RPM, but usually more power is made by advancing the timing, when knock-limited. See here on changing timing maps: http://www.ultimatesubaru.org/forum/topic/129946-frankenmotor-and-ecu-hacking/ Link to comment Share on other sites More sharing options...
one eye Posted November 7, 2013 Share Posted November 7, 2013 EA81 it scott!!!! Jeff 4 Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 7, 2013 Share Posted November 7, 2013 The flywheel off a 2.5l in a 97-99 legacy Outback is a lot heavier than the same year 2.2l one, so that would help with keeping it from stalling out. A 2.5L shortblock would help more... Superchargers won't help much at 1k rpm unless you have the supercharger's ratio set way faster than the crank and you won't be able to run the engine over 3k without the supercharger exploding at that point. Link to comment Share on other sites More sharing options...
NorthWet Posted November 7, 2013 Share Posted November 7, 2013 You can get some benefit by shifting the cam timing, even more so if it is a DOHC. The current cam timing is optimized for somewhere around 3k-4k. Adjust the cams so that the intake valve closes as close to BDC as practical, and if DOHC adjsut the phasing so that there is minimal valve overlap. 1 Link to comment Share on other sites More sharing options...
subnz Posted November 7, 2013 Share Posted November 7, 2013 (edited) All this ie changing cam timing, forcing induction, retarding ignition, isn't worth the expense for the small gains? if any? The motors turning over too slowly for any of these things to make that much of a difference. The design/characteristics of these motors (modern engines) is wrong to modify for torque at idling. engine too short stroking ie square to over square, [bore = stroke to, bore greater than stroke]. this short stroke design is best for high rpm. Need undersquare engines ie stroke greater than bore ie similar to old school ohv 6 cylinder ford/gm engines pre V8s over 50 years ago. for high torque values at low rpm but not good for rpms ( vibration - self destruction) Diesels are better because the are under square (stroking engines) also have about twice the compression (compression ignition) of gasoline engines so have stronger power impulses at idle (more torque) are more simple and don't need to be modified the same Edited November 7, 2013 by subnz Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 7, 2013 Author Share Posted November 7, 2013 All this ie changing cam timing, forcing induction, retarding ignition, isn't worth the expense for the small gains? if any? The motors turning over too slowly for any of these things to make that much of a difference. The design/characteristics of these motors (modern engines) is wrong to modify for torque at idling. engine too short stroking ie square to over square, [bore = stroke to, bore greater than stroke]. this short stroke design is best for high rpm. Need undersquare engines ie stroke greater than bore ie similar to old school ohv 6 cylinder ford/gm engines pre V8s over 50 years ago. for high torque values at low rpm but not good for rpms ( vibration - self destruction) Diesels are better because the are under square (stroking engines) also have about twice the compression (compression ignition) of gasoline engines so have stronger power impulses at idle (more torque) are more simple and don't need to be modified the same I understands its not THE best choice for low RPM Tork but its what Im going to stick with, and yes if theres any gain in lowend power then it is worth the effort , if I cam make a few simple adjustments or additions to accomplish this then Im all for it, You can get some benefit by shifting the cam timing, even more so if it is a DOHC. The current cam timing is optimized for somewhere around 3k-4k. Adjust the cams so that the intake valve closes as close to BDC as practical, and if DOHC adjsut the phasing so that there is minimal valve overlap. ok Its a bone stock SOHC the one that came in the car its a 90 EJ22 , so how would I do this? , move a tooth on the belt? or somekind off slotted adjustable cam? Link to comment Share on other sites More sharing options...
ivans imports Posted November 7, 2013 Share Posted November 7, 2013 boo on the delta cams put in a set in 2.2 and lost alot of bottom end good 3000and up but 1000-3000 dog was very dissapointed with them. Give it a sniff of NOS like a 15 hp shot jsut to get it outa the hole or mabee find a way to slightly addvance timing Link to comment Share on other sites More sharing options...
presslab Posted November 7, 2013 Share Posted November 7, 2013 Yup I have the "torque" cams too and the bottom end and idle is worse, you can see it in my dyno plot. Link to comment Share on other sites More sharing options...
Gloyale Posted November 7, 2013 Share Posted November 7, 2013 EA81 it scott!!!! Jeff He said he wants more power. lol Ohh.....I get it you think since it's so tiny the weight loss will give him more power? I just leave my Girlfrieind home if I want to drop 110Lbs. 1 Link to comment Share on other sites More sharing options...
NorthWet Posted November 7, 2013 Share Posted November 7, 2013 (edited) ok Its a bone stock SOHC the one that came in the car its a 90 EJ22 , so how would I do this? , move a tooth on the belt? or somekind off slotted adjustable cam? Basically, any engine can be made to have its torque peak anywhere in its rpm range (limited by VE at the upper RPMs). To lower the torque peak, you need to do the opposite of what most tuners do for more horsepower: Less radical cam timing, smaller intake tracts, smaller valves, less carburetion. And more rotating mass (heavy flywheel) to make better use of the less frequent power pulses. With work, you can make the EJ22 reach full torque at 100RPM... but it will suck by 1000RPM. If I were to do adjustable timing on the SOHC EJ, I would probably mount an extra idler wheel on the tension side of both T-belt runs, and make these idlers adjustable (like the fine adjusters on A/C tensioners). You could then use these to "dial-in" each cam's timing. The actual adjusting would have to be slow to allow for the tensioner to compress, and which one you do first is likely to be important (due to shared belt and tensioner), but my migraine is preventing me from thinking this through. Edit: IF you make the cam changes and use a narrowed intake runner, THEN... (endedit) You might also get some changes (hopefully good ones) by deactivating one intake valve of each pair. All of this will lower max HP and max usable RPM. Edited November 7, 2013 by NorthWet Link to comment Share on other sites More sharing options...
NorthWet Posted November 7, 2013 Share Posted November 7, 2013 Divorced t-case. Best advice. Trade reduced speed for increased torque at the wheels. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 8, 2013 Author Share Posted November 8, 2013 Best advice. Trade reduced speed for increased torque at the wheels. I know that will work, but why not ask and see what is possible Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 8, 2013 Author Share Posted November 8, 2013 boo on the delta cams put in a set in 2.2 and lost alot of bottom end good 3000and up but 1000-3000 dog was very dissapointed with them. Give it a sniff of NOS like a 15 hp shot jsut to get it outa the hole or mabee find a way to slightly addvance timing NOS, now that's interesting, don't know anything about that, Link to comment Share on other sites More sharing options...
86hatchback Posted November 8, 2013 Share Posted November 8, 2013 In the spirit of old bus/med duty truck engines. Would running an ej18 intake and heads with a 2.5 short block with heavy flywheel produce lots of low end torque via long stroke and small valves? Link to comment Share on other sites More sharing options...
