monk50 Posted November 6, 2013 Share Posted November 6, 2013 Questions? I have 2 2005 outback llbean models with the 3.0 engine. The inner cv boots are right above the catalytic converter and constantly "cooks" the inner cv boots; especially in stop and go traffic. Any ideas and remedies? Anyone made a shield that attaches to the engine? What about wraping the converter with the same material that I see motorcycle exhaust pipes have done. Would this change/harm/cause any problems with the O2 sensor etc? Would appreciate any help suggestions, contacts, web sites to help with this problem. Thanks gerald in NC Link to comment Share on other sites More sharing options...
avk Posted November 6, 2013 Share Posted November 6, 2013 How long did the factory boots last? Link to comment Share on other sites More sharing options...
presslab Posted November 6, 2013 Share Posted November 6, 2013 I have used a silicone CV boot from Dorman in a similar situation (CV boot near the turbo downpipe) and it has held up remarkably well. Link to comment Share on other sites More sharing options...
avk Posted November 6, 2013 Share Posted November 6, 2013 (edited) The 2005 3.0 model comes with 5EAT and has tri-lobal inner joints. Stock EPDM boot seems to be the best you can find. Edited November 6, 2013 by avk Link to comment Share on other sites More sharing options...
presslab Posted November 6, 2013 Share Posted November 6, 2013 On 11/6/2013 at 9:02 PM, avk said: The 2005 3.0 model comes with 5EAT and tri-lobal inner joints. Stock EPDM boot seems to be the best you can find. If an exact fit boot can't be found, there are the "universal" type, where it has various diameters you can cut down; silicone is very stretchy as well. I imagine one could be found that would work. Link to comment Share on other sites More sharing options...
avk Posted November 6, 2013 Share Posted November 6, 2013 (edited) I would be interested in that as well. They way it is, the inboard CV housing is not round and a universal boot would require a tri-lobal bushing. There has to be a cross-application that fits, but that hasn't been documented yet. Edited November 6, 2013 by avk Link to comment Share on other sites More sharing options...
presslab Posted November 6, 2013 Share Posted November 6, 2013 I see, the tripod boots I've seen are still round on the inside. Maybe the old boot could be cut down and used as a bushing. Link to comment Share on other sites More sharing options...
idosubaru Posted November 7, 2013 Share Posted November 7, 2013 On 11/6/2013 at 9:42 PM, presslab said: IMaybe the old boot could be cut down and used as a bushing. that's how i've seen it done on other manufacturers with these "non-round" cups. use the original as a bushing, slide the new boot over top. Link to comment Share on other sites More sharing options...
monk50 Posted November 7, 2013 Author Share Posted November 7, 2013 Thanks, I use the OEM cv boots, but traffic driving still cooks the boots. I was hoping for a method to sheld the boots from the heat given off by the cat located just below the inner cv boot. I have idea's of fabricating a shield from aluminum with fiberglass sandwiched between. Attach this to the engine bolt just above that would create a barrier between the boot and cat. When the engine is hot and the car stopped; heat from the cat cooks the cv boot and shortens it's life. Was hoping somone had already developed a solution. Thanks for any and all input. Monk50 Link to comment Share on other sites More sharing options...
idosubaru Posted November 7, 2013 Share Posted November 7, 2013 i've seen it for other applications and it works...but i've not seen it done for a Subaru exhaust. Link to comment Share on other sites More sharing options...
Gloyale Posted November 7, 2013 Share Posted November 7, 2013 On 11/7/2013 at 11:32 AM, monk50 said: Thanks, I use the OEM cv boots, but traffic driving still cooks the boots. I was hoping for a method to sheld the boots from the heat given off by the cat located just below the inner cv boot. I have idea's of fabricating a shield from aluminum with fiberglass sandwiched between. Attach this to the engine bolt just above that would create a barrier between the boot and cat. When the engine is hot and the car stopped; heat from the cat cooks the cv boot and shortens it's life. Was hoping somone had already developed a solution. Thanks for any and all input. Monk50 Do you have a lift or any spacer on your suspension? It could be the extra angle causing the tear....not the heat. I've never seen a H6 legacy with boot problems......not any more than any other Subaru.....I mean, the Cat's aren't any closer to the axles than they are on 4cyls......just that they are on both sides...not just the passenger. On turbo models the exhaust is even closer. I just feel like there is something else we are missing in the picture here. Link to comment Share on other sites More sharing options...
monk50 Posted November 9, 2013 Author Share Posted November 9, 2013 Car is completely stock. Think I am going to wrap the cat directly under the cv boot and see how that works. Monk50 Link to comment Share on other sites More sharing options...
shortlid Posted December 23, 2013 Share Posted December 23, 2013 This has always been an issue for Suabru had to reoplace the inner boot on my '99 Legacy L wagon with EJ22 casue the cat cooked it to death at 60k. Now my '03 Legacy GT seadn with EJ25 did the same thing at 90k. Link to comment Share on other sites More sharing options...
shortlid Posted December 27, 2013 Share Posted December 27, 2013 So the dealer said I can replace with a factory remanufactured axle. for $213 is that the going rate for a remaned one? Any online sources? Link to comment Share on other sites More sharing options...
idosubaru Posted December 28, 2013 Share Posted December 28, 2013 On 12/27/2013 at 11:20 PM, shortlid said: So the dealer said I can replace with a factory remanufactured axle. for $213 is that the going rate for a remaned one? Any online sources? really bad idea. keep your OEM axle as long as you can. remanned axles are notoriously inferior. you'd be throwing away a perfectly good axle for a lesser quality product. if you're unsure whether to believe me or not simply google or search any subaru forum about aftermarket axles, they're awful, even from Subaru. here's the best process for avoiding axle debacles and issues: 1. reboot OEM axles 2. use Subaru boots - aftermarkets have shorter lifespans, particularly the inner boots by the exhaust heat 3. if you must replace an axle for some reason buy a used OEM axle for $25-$33 and reboot it www.car-part.com Link to comment Share on other sites More sharing options...
shortlid Posted December 28, 2013 Share Posted December 28, 2013 Thanks for info, will clean and repack and replace with OEM boot. Link to comment Share on other sites More sharing options...
MilesFox Posted December 28, 2013 Share Posted December 28, 2013 On 11/7/2013 at 11:32 AM, monk50 said: Thanks, I use the OEM cv boots, but traffic driving still cooks the boots. I was hoping for a method to sheld the boots from the heat given off by the cat located just below the inner cv boot. I have idea's of fabricating a shield from aluminum with fiberglass sandwiched between. Attach this to the engine bolt just above that would create a barrier between the boot and cat. When the engine is hot and the car stopped; heat from the cat cooks the cv boot and shortens it's life. Was hoping somone had already developed a solution. Thanks for any and all input. Monk50 I have used an aluminum sheet bent to fit and secured with sheet screws. Large dryer clamps would work for this. If the axle is not yet popping and clicking severely, re boot it as the quality with remans is sometimes worse then the existing axle Link to comment Share on other sites More sharing options...
shortlid Posted December 29, 2013 Share Posted December 29, 2013 Can I clean the inner joint, re-pack it and reboot it without taking it completly out of the car? Link to comment Share on other sites More sharing options...
Gloyale Posted December 30, 2013 Share Posted December 30, 2013 On 12/29/2013 at 2:16 AM, shortlid said: Can I clean the inner joint, re-pack it and reboot it without taking it completly out of the car? Yes. But it's easier to remove it, and you have to unbolt the strut/knuckle bolts to tip the wheel out anyhow. Might as well take off the big 32mm axle nut and slide it out. Old EA stuff I would leave it cause pressing the axle in/out of the bearings can be tough, and even damage the bearings. But EJ stuff I'd just pull it all the way out and do it on the bench. Link to comment Share on other sites More sharing options...
shortlid Posted December 31, 2013 Share Posted December 31, 2013 Ok, can I seperate the inner fron the outer cv to get the new boot on the inner? Link to comment Share on other sites More sharing options...
Gloyale Posted December 31, 2013 Share Posted December 31, 2013 Yes once you unclip the boot and slide it down, there is a clip around the inner lip of the cup (inner end cup) Slip out the ring, and the jjoint will slide out. A snap ring holds the inner race to the shaft, remove it, and the boots can slide off the axle....then reassemble in reverse order. Link to comment Share on other sites More sharing options...
shortlid Posted January 1, 2014 Share Posted January 1, 2014 On 12/31/2013 at 6:01 AM, Gloyale said: Yes once you unclip the boot and slide it down, there is a clip around the inner lip of the cup (inner end cup) Slip out the ring, and the jjoint will slide out. A snap ring holds the inner race to the shaft, remove it, and the boots can slide off the axle....then reassemble in reverse order. Nice so I can do this peice mail, this would require just, brake cleaner, CV greese and and a new OEM boot. Link to comment Share on other sites More sharing options...
Gloyale Posted January 1, 2014 Share Posted January 1, 2014 And clamps 1 Link to comment Share on other sites More sharing options...
shortlid Posted January 12, 2014 Share Posted January 12, 2014 Well just pulled the cracked boot back and the greese is white and milky. So thinking moisture got in there, guessing that likly comprimised the joint. Also noticed the seals where the axle goes into the front diff are weeping. Guessing it would be easy to replace that while i have the axle out. Guess i shoudl return the stuff I bought to repack and re boot the axle thats in there. Link to comment Share on other sites More sharing options...
J A Blazer Posted January 13, 2014 Share Posted January 13, 2014 I had this problem with my 2000 OBW 2.5; front axles were replaced 5 years ago and were doing fine but as soon as I replaced the entire exhaust system the inner boot on the passenger side, which is directly above the cat, ruptured. I'm convinced it is because the replacement cat does not have a heat shield. Would love to see pictures of the heat shields that other posters have fabricated. Link to comment Share on other sites More sharing options...
