I tripped over this . EA81 upgrade to SPFI
http://www.leoneturbo.com/docs/EA81_SPI_guide.pdf
All EA81's (talking non-turbo here) were
equipped with carburetors from the factory. Either the Hitachi 2 barrel,
or the Carter-Weber single barrel. Both have their array of problems, are rather anemic in the performance
department, and have a vast array of complicated vacuum lines. As well as extra systems to make them economical,
and environmentally friendly - even to the point of using computers to control the carburet
or mixture adjustments.
Fortunately, Subaru gave us an excelent upgrade path. In 1986,
Subaru introduced the Single Point Fuel Injection
(SPFI) to the US market on it's EA82 engine. This engine happens to share the exact same intake ports on the heads,
and the same overall length for the intake manifold as the EA81. Sadly the EA82 engine, while sporting an almost
indestructible, very simple fuel injection system, has troublesome timing belts, is prone to ticking lifters, and (because of the
timing belt arrangement) can be difficult and time-consumeing
to work on. It also does not fit in the EA81 vehicle
engine bay without modifications to the frame rails, and moveing the hill-holder valve.
 Because of the similarities between
the manifolds, the almost self contained fuel injection manifold from the EA82 bolts straight onto the EA81 engine with
minimal modifications
