If you are running one odd tire, you will be ok. IF you are running a PAIR of different size tires, mount them diagonal from eachother.
OR, if you run them in the front, (assuming automatic) use the FWD fuse and limit your driving until you get matching wheels. for manual trans mount them diagonal
no you can't do what you said.
1. use the FWD fuse
or
2. milesfox has another option which shops around here use for installing two new tires on a subaru.
if it has a rear locking VLSD differential then you can't have mismatched tires on the rear though so option #2 won't work without frying your rear diff.
