92_rugby_subie Posted November 9, 2013 Share Posted November 9, 2013 So Im looking at buying a new water pump for my replacement engine (might as well put a new one on rather than use my other one) and I know about the differences between 105mm and 110mm pumps and Ive been searching, however there seems to be a lot of "you can do this if" and "no that wont work" type of things going on... So here I have a link: http://www.partsgeek.com/mmparts/water_pump/subaru/loyale.html That shows Aisin and GMB water pumps at pretty decent prices, both made in Japan last I checked so should be of OEM quality... My question is... The motor going INTO the car is out of a 1990-1994 Loyale with A/C... Ned doesnt have A/C (1986 GL Sedan) so if I swap my alternator bracket onto the new motor, then I use the 105mm water pump right? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 9, 2013 Author Share Posted November 9, 2013 On 4/17/2013 at 2:46 PM, Gloyale said: Actually it not "turbo or non turbo"It's factory a/c or dealer/non a/c. If the a/c compressor is inboard of the alt, it factory a/cFactory ac = short pump. 105mmAll others = long pump. 110mm Nevermind, Gloyale answered it for me here... Finally found the thread by searching google... now to check part numbers for the correct shaft... For anyone searching... Non-AC cars need the 110mm pump. 1 Link to comment Share on other sites More sharing options...
Prwa101 Posted November 9, 2013 Share Posted November 9, 2013 Personally 5mm difference ain't much. That's .1" But go with the same size one that came on the motor your putting in? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 9, 2013 Author Share Posted November 9, 2013 The pulley is whats different apparently, like the belts will not align correctly? I heard I need to swap my alternator bracket over to the new motor anyway so Im gonna go with the 110mm pump... Aisin Engine Water Pump WPF-003 says "without A/C on fitment" and "110mm" on another site... so thats what Im gonna go with Link to comment Share on other sites More sharing options...
jono Posted November 9, 2013 Share Posted November 9, 2013 Well, I'l be....down under we differentiate the deck heights of EA82 water pumps for thje belt/pulley types. 105mm deck height for the multi rib flat accessory drive belt and 110 deck for old school V belt drive. A press and press plates are really all that are needed to alter the deck height. I followed all the advice from somewhere, got the wrong pump and paid an extra 10 bucks for the turbo listing , ended up in the press for correction. Same pump - just 5mm difference in fitted height of its little outer wheel ! Link to comment Share on other sites More sharing options...
TomRhere Posted November 10, 2013 Share Posted November 10, 2013 110mm pump, the drive pulley bolts on. 105mm pump, has studs to mount the clutch fan. If one finds that they got the 105mm unit instead of the 110mm unit, you can install some studs and slip washers on those before installing the drive pulley, then install the nuts. Read about that trick on here a few years back. Studs are the same as one would find holding the carb to the manifold. Should be able to find them on a "HELP" rack at a parts store. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 10, 2013 Share Posted November 10, 2013 I has been worried about the Water pump on my Subaru "BumbleBeast" because its EA82 engine has been working since year 1985 with the factory Water Pump (Maybe it has lasted more because I run it without thermostat since that year... or maybe I just has been Lucky), I've never changed that so far, but it already has more than 300K miles and I'm planning to do a Timin' belt job next year, so a Fresh Water Pump should be added then. So some month ago, I started collecting parts to do said timing belt job, and I obtained locally a Brand New Water Pump which came inside a "Beck-Arnley" box, part Number 131-2027 and the Water Pump itself says: "NPW Made in Japan" According to ~► this web site, that water pump is 105 mm but there says it Fits the "Subaru DL and the Subaru XT" ... my Question is due to that somehow confusing info: My 1985 EA82 Subaru GL wagon with factory (inboard hitachi) A/C uses the 105 or the 110 mm tall Water pump? Kind Regards. Link to comment Share on other sites More sharing options...
ivans imports Posted November 10, 2013 Share Posted November 10, 2013 Addjust pulley mount with press to right height Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 11, 2013 Share Posted November 11, 2013 Thanks, I Know I could do that, but somehow my Question remains unanswered: On 11/10/2013 at 4:16 PM, Loyale 2.7 Turbo said: ... My 1985 EA82 Subaru GL wagon with factory (inboard hitachi) A/C uses the 105 or the 110 mm tall Water pump? ... Kind Regards. Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 11, 2013 Author Share Posted November 11, 2013 105mm pump since it's factory AC Link to comment Share on other sites More sharing options...
jono Posted November 11, 2013 Share Posted November 11, 2013 Jes, flat ribbed or V belt ? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 12, 2013 Share Posted November 12, 2013 (edited) My Subaru "BumbleBeast" has V belts ... The Flat ribbed belt came on the EA82's with Spider intake Manifold (XT's) isn't it? That is Why the info on e-Bay is confusing, they wrote that it fits the XT and the DL, and DL's here came without A/C. On 11/11/2013 at 7:57 PM, 92_rugby_subie said: 105mm pump since it's factory AC This is the Straight kind of Answer I was Lookin' for! Thanx, Kind Regards. Edited November 12, 2013 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
jono Posted November 12, 2013 Share Posted November 12, 2013 Not sure weather L Series EA82 got factory installed AC. Certain the earlier EA81 MY sries were dealer installed and aftermarket. I got an EA82 that was AC and used two V belts for same path, it is a 110mm deck I am sure Link to comment Share on other sites More sharing options...
TomRhere Posted November 13, 2013 Share Posted November 13, 2013 On 11/12/2013 at 8:55 PM, jono said: Not sure weather L Series EA82 got factory installed AC. Certain the earlier EA81 MY sries were dealer installed and aftermarket. I got an EA82 that was AC and used two V belts for same path, it is a 110mm deck I am sure Still, it boils down to whether the A/C compressor is inboard of the alt (factory A/C) = 105mm pump, or if the A/c compressor is outboard of the alt (non/aftermarket) = 110mm. There are work-arounds to use either pump, but that is the jist of what they are for. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 13, 2013 Share Posted November 13, 2013 On 11/12/2013 at 8:55 PM, jono said: Not sure weather L Series EA82 got factory installed AC. Certain the earlier EA81 MY sries were dealer installed and aftermarket. I got an EA82 that was AC and used two V belts for same path, it is a 110mm deck I am sure As far as I know, There are four (4) versions of the A/C compressors for the EA82 engined Subarus; Hitachi, Nippondenso, Panasonic inboard and Panasonic outboard. The difference between the two Panasonic systems is the location of the compressor only; but the most usual ones are these: ► The Factory A/C has the Compressor installed between the Power Steering Pump and the Alternator, and thus means it is an "Inboard" A/C = Factory, usually Hitachi but there could be Panasonic and the more scarse Nippon Denso. ► The Dealer installed A/C has the Compressor installed "outside" Near the Battery, and the Alternator is the one that gets between said Compressor and the Power Steering Pump; and thus means it is an "Outboard" A/C = Dealer option, Panasonic. So, my 1985 EA82 with Factory installed hitachi inboard compressor, and according to the above written answers, it uses the 105 mm tall Water pump. Kind Regards. Link to comment Share on other sites More sharing options...
suprjohn Posted November 15, 2013 Share Posted November 15, 2013 Hey All! interesting! wish i'd seen this thread prior to installing my new water pump; after exchanging it twice, and still not having the right height, i installed longer bolts from the back side with jam nuts. i then used washers to space the pulley out correctly, and fastened with nylok nuts. seems to be working so far. '89 DL with A/C JOHN Link to comment Share on other sites More sharing options...
Gloyale Posted November 15, 2013 Share Posted November 15, 2013 Pretty much only GL-10s, turbos, and XT's uses the 105 mm, "factory" A/C setup. All other models use the 110. The 105 pump can be used with the correct pulley. It's like this. If the pulley is thicker, fit's on over the studs, and then has it's own studds for the Clutch fan.......You need a 105 If the pulley is thinner slips right over the studs and then the fan bolts onto those same studs......110 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 16, 2013 Share Posted November 16, 2013 On 11/15/2013 at 5:42 PM, Gloyale said: Pretty much only GL-10s, turbos, and XT's uses the 105 mm, "factory" A/C setup... My 1985 "BumbleBeast" EA82 has Factory "inboards" A/C, and the Waterpump seems to be: On 11/15/2013 at 5:42 PM, Gloyale said: ... the pulley is thinner slips right over the studs and then the fan bolts onto those same studs......110 ... So 110? ... Even more confusion to the Mix, because this seems to be backwards comparing to the above posts, Such like These: On 11/13/2013 at 1:12 AM, TomRhere said: ... whether the A/C compressor is inboard of the alt (factory A/C) = 105mm pump ... On 11/11/2013 at 7:57 PM, 92_rugby_subie said: 105mm pump since it's factory AC Maybe I'll wait 'till the Moment I do the Timin' Belts Job, in order to Remove the Stock, 300K Miles old WaterPump, to see if it is 105 or 110 mm tall shaft... Link to comment Share on other sites More sharing options...
Trident Posted November 20, 2013 Share Posted November 20, 2013 Loyale 2.7 - I agree on the confusing part. I'm needing to order one for my '86 GL right now but all the contradictions you highlighted gives me pause. I've got factory A/C which is inboard of the alternator, uses v-belts and the current water pump has studs that the fan mounts to. I'm leaning towards 110mm...... 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 20, 2013 Share Posted November 20, 2013 My subie's setup seems to be identical to yours... If you remove your Subie's Waterpump, please give us Feedback (and Photos if you could) of the Waterpump and the measurement of the Shaft tall it uses. Kind Regards. Link to comment Share on other sites More sharing options...
Trident Posted November 21, 2013 Share Posted November 21, 2013 ok, so I removed the water pump from my 1986 GL (Factory A/C as far as I can tell, the compressor inboard of the alternator & uses V-belts) I measured from these 2 points on the pump and I received this measurement So........110mm?.....if I'm measuring correctly 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 21, 2013 Share Posted November 21, 2013 Many thanks to you, Trident, for the Photos and Measurements. I Measured my Brand New NPW Japanese Waterpump exactly as you did, and the Measurement is Equal to yours: 110 mm ... ... Despite that the Website (posted above on Post Nº 7) says it should be a 105 mm one... However, I'm glad I obtained the Right Waterpump for my "BumbleBeast" Kind Regards. Link to comment Share on other sites More sharing options...
Trident Posted November 21, 2013 Share Posted November 21, 2013 you're welcome Loyale 2.7, not a problem at all. I'm gonna go with the 110mm for mine as well. Now the question is.......which Aisin pump is 110mm? the 007 or 003? 2 Link to comment Share on other sites More sharing options...
Gloyale Posted November 21, 2013 Share Posted November 21, 2013 On 11/21/2013 at 4:19 PM, Trident said: ok, so I removed the water pump from my 1986 GL (Factory A/C as far as I can tell, the compressor inboard of the alternator & uses V-belts) That would be the dealer installed system. GL-10s had it factory and the pump is outboard of the Alt. Your GL had it added at the dealership. Link to comment Share on other sites More sharing options...
Gloyale Posted November 21, 2013 Share Posted November 21, 2013 On 11/13/2013 at 1:12 AM, TomRhere said: Still, it boils down to whether the A/C compressor is inboard of the alt (factory A/C) = 105mm pump, or if the A/c compressor is outboard of the alt (non/aftermarket) = 110mm. This is backwards Link to comment Share on other sites More sharing options...
