lsabol Posted November 9, 2013 Share Posted November 9, 2013 I took my 07 Impreza TS (155,000 miles) for an oil change at my local Subaru dealer today and was told that my front axle boot has split. The service guy said this is not an emergency but did encourage me to replace it, and to use genuine Subaru parts, which he estimates the cost at $420. Questions: do I need to have this work done at all? Should I use Subaru parts. Any info appreciated. Thanks! Laurie Sabol Ayer MA Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 9, 2013 Share Posted November 9, 2013 Yes, eventually get this fixed. The standard fix is to replace the front axle, known as a half shaft as a complete unit including new boots. Otherwise, the grease gets thrown out the split boot, and road crud with road salt gets thrown into the open boot to eventually damage the bearing. This could take a year or two to happen, but you don't know how long the boot has been split. It is not a safety issue, or a break down issue that would leave you stranded. When the bearing starts going bad, it will start making noise. Quote Link to comment Share on other sites More sharing options...
Longtrailside Posted November 9, 2013 Share Posted November 9, 2013 Just did mine. Use subaru parts if you can because the aftermarket one size fits all one are a pain to install by yourself (bad fitting). The job can be done in under an hour if you have all the right tools and knowledge. It will also save you 380 dollars. Quote Link to comment Share on other sites More sharing options...
Olnick Posted November 10, 2013 Share Posted November 10, 2013 Laurie--Yes, you should replace the axle(s). Yes, you should avoid aftermarket junk and use genuine Subaru axles. No, don't have a dealership do it, it'll cost you an arm and a leg! Find a small independent shop and get an estimate for labor only to replace axle(s). Then consider good, rebuilt Subaru axles. I recommend this guy, Marshall Wolf--he does quality work and is a straight shooter: FW Enterprises LLC.Formerly: “MWE Axles”.6401 N. Broadway. Unit DDenver, Colorado.80221Phone: 303-522-8070 Email: mwolf1303@juno.com Good luck. Quote Link to comment Share on other sites More sharing options...
