IT can hold park while running, but once you shut it off, it will roll. I had to get by like this, and keep a block of wood in the floorboard to throw under the car as a parking brake. Then when time to go, roll forward and pick it up. Then i chopped a wire to lock in the rear drive and removed the broken axle. then i finally replaced it and restored the wire.  This is a dynamic platform, if you will.
