ej swap spfi question
would it be posable to run the loyale ecu and spfi set up on a ej18 i know the sensors and plugs will be wrong or missing but would it run  i might be geting a ej18 for a trade on some work i dont think it would be as good as stock but if it will work i have extra ea82 stuff ecu wiring harness whole care less the body if its possable to do it would make a great combo for the  bug or if it would pass smog would it be worth doing the swap on a loyale and for that matter would the spfi work on a ej2.2 the 2.2s get better gas mileage than the ea82 dose would the throtle body give enuff fuel to run a 2.2 im sure its just easyer to use the right ecu and harness than to  get and mod all the parts to run spfi on a ej engine just curiose if anyone has tryed something like this or has tryed to run the spfi setup on any other motors kinda like a standalone setup
Have run the spi stand alone but never on ej motor this whould be crazy hard to get the right signals outa the ej motor if you could find a way to boltup a diss to ej but then plug wires coil ect I'm shure it would work good and get decent mpg. But apples to oranges better to find a ej harness to put into your car
Nope. Wouldn't ever pass in Ca. They do an underhood inspection. Very tough state. Plus, you have all of the problematic issues listed above. For the money you would spend alone on trying to put in a distributor, you could buy a good used Subie. Add to that the fuel and timing maps in the ECU being different..... Get the correct harness and ECU.
The dizzy can be found on a ford escort and it will bolt to the passenger's side head - there'a plate that covers the hole for the dizzy to bolt to and mate with the cam shaft.
There was actually a factory carb fed EJ that came out I think in Latin America - there are pics around of this.  One of the boys in WA Australia built a weber fed EJ22 with one of these escort dizzys.
So I'd say it could be done, and the fact that the EJ18 is the same capacity as the EA82 I don't see why the SPFI couldn't work on the EJ18 with some effort.
Cheers
Bennie
This is something the vw community has done over and over again. Older fuel injection systems running newer engines and vice versa. In my opinion, a 4 cylinder engine is a 4 cylinder engine, many times the timing and the maps are fine if the power rating for the setups are within reason. We have found some issues putting a multiport engine with an ecu meant for single port, 16 valve on an 8 valve fuel injection. but there are simple tricks to fool the ecu. Bigger injectors or a larger MAF housing, ect. There are companies that have created an entire industry for making custom tunes for these swaps. for example, a 16 valve turbo running fuel injection from a NA 8 valve with a chip. As long as you can get a distributor to mount up, and the injectors mount, the rest should be straight forward.
My vw quantum is running its original 1982 CIS-L injection with the engine block from a 94 jetta, cylinder head from one side of a 91 Audi V8, Saab distributor, Mercedes injectors, and WUR from a porche. So anything is possible if your willing to put some time into tuning.
Ya, that's a big plus. Here in NH the only emission testing is for obd2 cars, cars prior to 96 are a free for all. They're supposed to do visual checks but as long as you have a friend that's an inspector, your good. Even the obd2 cars are easy to trick, test is done through the old test plug. So, if you have a good tune with the emissions equipment wrote out, your good.
Aggreed that it can be done. I have a '78 Suburban SB 400 that I built to 300HP and transplanted BB FI onto. I had to re-write the fuel and timing maps and write a seperate PROM for passing emissions. Of course, that was years ago and now it has passed the 25 year mark. I'm no stranger to tuning or hodge podging parts together to make something unique or better. Just pointing out that for his particular situation, it's not practical nor will it pass. If it were for an offroad buggy, I'd say go for it. It would be a great learning experience.
