1994 Loyale 4x4 Wagon fuel tank removal
If i remember correctly there is a drain hole bolt if you still have gas. Then put a jack under the the rear differential because you have to unbolt two nuts holding the mustace bar on to lower it so the gas tank can come out also because you probably dont want it to just drop down hard on the axels. After that unbolt the gas tank from the car and its out.
