Bekokatt Posted November 15, 2013 Share Posted November 15, 2013 I'm looking to put a gl gauge cluster in my DL which lacks tachometer, a voltmeter, but, most importantly to a car with 272008 miles, the oil pressure gauge. I bought the cluster, but, it's not plug and play. I've heard I can take the dash, which has right wiring harness and use it. Will that all plug into my DL properly? Is easier to splice some wires? If anyone has any instruction that'd be great! I'll make a guide when I'm finished. Link to comment Share on other sites More sharing options...
Gloyale Posted November 15, 2013 Share Posted November 15, 2013 It's not easy. Swapping entire dash might work. If the cars are in the same year range. Years break down like this 86,86 87 88+ If it were me, and I was dead set on doing the swap....I would get FSM diagrahms for each dash and repin/cut/solder the wires at the back of the dash. That's what people ussually do for DigiDash conversion. In order to get a working Oil Pressure gauge you will need to swap a sending unit onto the Oil Pump. If you are really set on it I can copy Pinouts from the 2 dashes for you if you want. Link to comment Share on other sites More sharing options...
wallaby Posted November 15, 2013 Share Posted November 15, 2013 i have considered this multiple times for my DL brat.....it is the only part of the GL that i would really like to have(can do without power windows etc) i have a whole GL parts car so would swap dashpad, glovebox, instrument cluster and related wiring...would probably have to remove the windshield?? BUT as stated thats a LOT of work.... i am leaning towards some fabricating on the dash and installing aftermarket gauges - but that will take some effort too but the car would still be drivable while in process have not discounted this swap completely but it is getting less attractive capillary type oil pressure gauges are cheap and easy to install what might be more attractive is an EJ22 and instruments from a legacy.......... Link to comment Share on other sites More sharing options...
Bekokatt Posted November 15, 2013 Author Share Posted November 15, 2013 I like the crank windows, the lack of power mirrors. Simplicity. I've got a tranny, drive shaft, and rear axle ready for a 4wd conversion. I'm excited for that. Just figuring my gauge cluster now. If you have any pinouts or diagrams that'd be great! Link to comment Share on other sites More sharing options...
the sucker king Posted November 15, 2013 Share Posted November 15, 2013 what year and engine is this car? Link to comment Share on other sites More sharing options...
Bekokatt Posted November 15, 2013 Author Share Posted November 15, 2013 On 11/15/2013 at 7:35 PM, the sucker king said: what year and engine is this car?The car is a 1987 DL 3 door coupe with the 1.8 EA82 Fuel Injected non-turbo. Link to comment Share on other sites More sharing options...
diiirrtydaan Posted October 20, 2014 Share Posted October 20, 2014 I've been trying to research the same conversion. Was the project finished? Link to comment Share on other sites More sharing options...
