Cisco Posted November 15, 2013 Share Posted November 15, 2013 Hi. The other day I had to quickly put on my brakes to make a left hand turn and my little Saffire engine died. She started right back up but without the RPM gauge regestering and the heater stopped working. Now her engine stops at every stop sign and signal, sometimes just slowing down. Why would all these seemingly unrelated things happen at once? Would love to know what I should be looking at. A mechanic suggested I clean the carb, but spraying in the carb cleaner didn't help. Thank you for any suggestions. Cisco Link to comment Share on other sites More sharing options...
ArtRat007 Posted November 15, 2013 Share Posted November 15, 2013 vacuum leaks perhaps? spray carb cleaner around the base of the carb if idle changes that could be it. check all vacuum lines. DId you try to just adjust your carb? sometimes they just get old and need help 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 16, 2013 Share Posted November 16, 2013 (edited) Important details, such as Subaru Model / Year \ Kind of Engine are Missing; but by reading this: ... She started right back up but without the RPM gauge regestering ... If the RPM's needle quit working, it means that the Ignition Module inside the Distribuitor is about to say good bye; but since you wrote that the Heater also quit; perhaps it could be a Loose Fusible Link, and / or Loose Wires \ Blown fuse. I Kindly suggest you to Start checking the Wirings. Kind Regards. Edited November 16, 2013 by Loyale 2.7 Turbo 1 Link to comment Share on other sites More sharing options...
Cisco Posted November 16, 2013 Author Share Posted November 16, 2013 Thanks for the tips guys, will check on wiring and work on carb. It is by the way (sorry thought I mentioned this) I have a 85 Subaru GL wagon and she is a dream. Thanks again 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 16, 2013 Share Posted November 16, 2013 My beloved Subaru "BumbleBeast" Wagon, is 1985 like yours; it has been part of my family since then... is a Dream too. Kind Regards. 1 Link to comment Share on other sites More sharing options...
