GTgal Posted April 27, 2004 Share Posted April 27, 2004 Does anybody have any recommendations on ways to deep clean Subaru fuel injectors? I'm not talking about that liquid you add " every 3 thousand miles" to your gas tank. My 2000 GT has been pinging since before 30,000 miles - currently have 52,000. Have used mid-grade gas for a year to to try to counteract. Have replaced anti-knock sensor -- no difference. Subaru dealer says I need a fuel injection cleaning for 129.00. Is there a DIY throttle body alternative? Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 27, 2004 Share Posted April 27, 2004 There are tune up places that will do that injector cleaning, but I'm not sure it is worth the money. You could always pull the injectors and clean them with carb and choke cleaner by setting the tips in a bath of the cleaner. I tend to believe that with the additives in most gas today, the injectors should stay pretty clean, but that's just my OPINION. As far as the throttle body, that is just for airflow in most newer cars. Putting anything there won't clean the injectors. Maybe your temp sensor is causing the timing to advance or retard when it shouldn't. Does it ping when the engine is cold as well? Link to comment Share on other sites More sharing options...
Impreza_WRX_STi Posted April 27, 2004 Share Posted April 27, 2004 Throttle body and fuel injectors are sifferent. But both can be done, and both help. Maybe put a can of Seafoam in the gas tank. It is hard to find, but it works. Most typical FI cleaners burn harder than gas, this one is opposite it is more oil based and cleans very well, at least it works well with my 215,000 mile Impreza! Cleaning the TB is easy, take off intake to throttle body, get TB cleaner and spray it in and use paper towels (some people hate to use paper towels) to wipe around the inside of the TB. if you want to, and it helps. Plug a screwdriver on the outside of the TB, by the cables to hold the valve open. spray in there and wipe it in there to. If you do this try to focus on spraying the sides of the TB and not down the intake manifold. Hope this helps. If you need more in-depth info PM me! Max Link to comment Share on other sites More sharing options...
oddcomp Posted April 27, 2004 Share Posted April 27, 2004 me myself and I suggest if you cna do it to find a old fuel injection pump dig up a fuel injector driver schematic run the fi pump to a small tank your preferance of injector cleaner and position the injector so it dumps back into the tank and run this little setup for about half hour to hour on each injector btw i do suggest some kind of fuel psi regulator as well it *should* do a decent job of cleaning injectors <or tbi stuff just take off the tbi and put it over the cleaner container just something i been thinking of doing .. for a while but never have gotten to the reality part of the idea yet Link to comment Share on other sites More sharing options...
rugbyben Posted April 27, 2004 Share Posted April 27, 2004 try the seafoam. that stuff works great. stay away from the other dump in FI cleaners. they work okay on the injectors as long as you run your engine hot every time you run it for that whole tank of gas. but if you go a short distance and it doesnt get hot enough that stuff wont burn and it can gunk up the injectors and will foul your plugs. I used the STP kind in my jeep wrangler, whose engine runs very cool. and it made a real mess. seafoam fixed that and made it run better then before. Link to comment Share on other sites More sharing options...
GTgal Posted April 28, 2004 Author Share Posted April 28, 2004 Tiny, Yes it does ping when the engine is cold and when it is hot - doesn't seem to matter. I think I will try a combination of all of the suggestions. btw, where can you get this Seafoam? Sounds great. Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 28, 2004 Share Posted April 28, 2004 I'm thinking you'd almost need a pulse generator to make the injector work, but what do I know??? Link to comment Share on other sites More sharing options...
sprintman Posted April 28, 2004 Share Posted April 28, 2004 FWIW. A few add-to-fuel ones work well. Techron, Redline S1-1 (approved by BMW), BG44 (very aggressive), and of course Subaru have the spray stuff that cleans TB etc. Even the non Sube dyno tune place that does mechanical work for me carries the OEM Sube stuff and swears by it. Link to comment Share on other sites More sharing options...
AussieIan Posted April 28, 2004 Share Posted April 28, 2004 Here is some more info, http://www.diynet.com/diy/ab_auto_fuel_system/article/0,2021,DIY_13679_2276265,00.html Link to comment Share on other sites More sharing options...
Hondasucks Posted April 28, 2004 Share Posted April 28, 2004 yes you would need a pulse generator, but you could make a simple circuit with a 555 timer to drive the injectors. If you just hold them open you will burn them out. Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 28, 2004 Share Posted April 28, 2004 It's hard for me to believe the injectors are bad at 52,000 miles. Hopefully, whatever you do will help. Have you ever tried just resetting the ECU? Link to comment Share on other sites More sharing options...
Impreza_WRX_STi Posted April 28, 2004 Share Posted April 28, 2004 Yeah, my fuel injectors went bad at 211,000 miles on my 93 Impreza. I am not sure where you can get seafoam in oregon. It is about a 16 oz white steel can, it is shaped like Marvel's Mystery Oil. Maybe if you do a google search it can tell you where you can find it locally. Maybe carquest, or napa. I know here in illinois Auto Zone don't have it. Max Link to comment Share on other sites More sharing options...
Atomic Robot Posted April 28, 2004 Share Posted April 28, 2004 I'd never heard of this Sea Foam stuff, but it sounds interesting. Here's a link I found: http://www.seafoamsales.com/motorTuneUp.htm It's supposed to be available at a couple of auto chains around here; I wonder how much it costs... Link to comment Share on other sites More sharing options...
oddcomp Posted April 28, 2004 Share Posted April 28, 2004 seafoam works well and the injector driver things i know of usually use pulse width modulation to control the injector opening and closing still rebuilding my collection of fuel injection stuff after losing 60 gigs of data ackk!!!! and then had a power failure whiel trying to recover it double ack!!!! so just starting over Link to comment Share on other sites More sharing options...
GTgal Posted April 29, 2004 Author Share Posted April 29, 2004 I don't think my fuel injectors need replacing. When I had my 30,000 mile service done at the local Subaru dealer, they said they were dirty and needed to be cleaned . The car was pinging at that time occasionally, that's why I was thinking the problem could be the fuel injectors. Several months later it was pinging more often, so I brought it in for service. They said the pinging was "within normal range" ( like any pinging should have a normal range ) and attributed it to my Ganzflow intake, so they refused to fix it. Ok, maybe I should have removed the intake first but it pings with or without it. I have used Techron -- no difference. Reset the ECU 3 times. It seemed to help right after I did it, but then went back to its normal pinging. Excuse me for my ignorance, but what is a pulse generator? btw - this dealer just replaced my radiator free under warranty this week when my boyfriend discovered a small seam leak near the bottom rad hose. And I wondered where that slow loss of coolant was coming from. Thought it might be a head gasket. I wonder if others had this problem. Link to comment Share on other sites More sharing options...
Hondasucks Posted April 29, 2004 Share Posted April 29, 2004 I think your pinging could possibly be caused by carbon deposits in your combustion chambers. The carbon acts as a sponge, soaking up some of the fuel and leaning it out, making it ping. I motorvac'ed my Legacy at like 185k and I swear it added another 15HP.. It only cost me about $20 to do it, but if your car is still under warranty, take that intake off and take it in and have them look at it. Link to comment Share on other sites More sharing options...
Tiny Clark Posted April 29, 2004 Share Posted April 29, 2004 A pulse generator is used to create a series of electronic pulses that would simulate what your ECU puts out to the injectors. You'd need to know voltage requirements for the injector before you even thought about setting up something to clean them. As you said, you don't think they are bad, and I don't either. I am surprised you don't have any fault codes in your ECU with that problem. Link to comment Share on other sites More sharing options...
oddcomp Posted April 29, 2004 Share Posted April 29, 2004 ummm hondasucks.. it was my understanding that the carbon deposits would get hot enough to glow at times creating hotspots that would preignite the fuel-air mix i'll have to go back through my mountain of books again to make sure i am remembering correctly <really bad memory> this works for carbon removal most of the time go get a vacum T from a parts store and a small aquarium air regulator find a source of manifold vacum put the t in and the aquarium thingy and run a hose into a bottle of marvel mystery oil adjust the regulator so you notice smoke out the exhaust and go for a drive with mid range rpms it might freak out teh ecu if your running fuel injection and its gonna smoke alot but it should clear out alot of the carbon crud also regular highway driving helps alot also i doubt mine has much carbon in it sicne i am on highway 30 everynight from longview to st'helens oregon and tend to get on it more than i should at least i know its cleared out Link to comment Share on other sites More sharing options...
myles Posted April 29, 2004 Share Posted April 29, 2004 ummm hondasucks..it was my understanding that the carbon deposits would get hot enough to glow at times creating hotspots that would preignite the fuel-air mix i'll have to go back through my mountain of books again to make sure i am remembering correctly <really bad memory> this works for carbon removal most of the time go get a vacum T from a parts store and a small aquarium air regulator find a source of manifold vacum put the t in and the aquarium thingy and run a hose into a bottle of marvel mystery oil adjust the regulator so you notice smoke out the exhaust and go for a drive with mid range rpms it might freak out teh ecu if your running fuel injection and its gonna smoke alot but it should clear out alot of the carbon crud also regular highway driving helps alot also i doubt mine has much carbon in it sicne i am on highway 30 everynight from longview to st'helens oregon and tend to get on it more than i should at least i know its cleared out I wonder if you're significantly shortening the life of your cat. by running that much MMO through it. Just thinking out loud... Link to comment Share on other sites More sharing options...
99obw Posted April 29, 2004 Share Posted April 29, 2004 My understanding has always been that any feature in the combustion chamber that protrudes or is sharp will get much hotter and cause preignition. Link to comment Share on other sites More sharing options...
oddcomp Posted April 29, 2004 Share Posted April 29, 2004 well i suppose you would if you ran it continuously just the same way a car that burns oil will mess it up and thats kinda what i meant by the hot carbon spots since its the edges that are thin and get the hotest thats why any motor i tear downf or a rebuild i spend some time with a die grinder smothing out all sharp edges in the heads <that also helps when done to the oil return passages helps it get back to the pan faster Link to comment Share on other sites More sharing options...
GTgal Posted April 30, 2004 Author Share Posted April 30, 2004 About the catalytic converter, will any of the deposit residue from cleaning the combustion chambers plug or harm it? Has anyone tried adding just a little bit of diesel fuel when the tank was about a 1/4 full and running it down the freeway, then filling it with premium? Link to comment Share on other sites More sharing options...
Esteban32696 Posted April 30, 2004 Share Posted April 30, 2004 " Seafoam" is available at Carquest, & NAPA Auto Parts for $5/can.Treats up to 25 gallons.Works great on cars & 2 cycle engines. Link to comment Share on other sites More sharing options...
86subaru Posted April 30, 2004 Share Posted April 30, 2004 you can find seaform at napa ,i use the injector cleaner from gm ,the engine cleaner stuff Link to comment Share on other sites More sharing options...
oddcomp Posted April 30, 2004 Share Posted April 30, 2004 the carbon deposits "could" plug up the cat.. but if you have that much carbon .. well thats gonna be teh least of your worries usually the carbon will break up once it breaks loose especially if you have a turbo Link to comment Share on other sites More sharing options...
