Oil pressure light when just cranking after engine rebuild
Just rebuilt engine with new bearings. Cranking for approx 1 minute and the oil light doesn't go off. In the past, knowing everything was lubricated well, I've never tried this, just left it fire and if oil light didn't go off after 2 or 3 seconds (always did) I'd be prepared to shut it off.  Anyone ever tried this method to make sure the pump is pumping oil? Should the light go off with just normal cranking after a minute? TIA
Yeah.....the oil pump will take a bit to prime.
It is a good idea to do that way though.
Just crank a few more times till it goes out before reconnecting the coil and running.
If it REALLY doesn't want to prime, you can jack the rear of the car up as high as you can to tip the oil forward into the pump cavity.
It's actually my motor he's talking about. I cranked it for about a minute. 10 seconds of cranking, 5 second pause, repeat, for a total cranking time of about 1 minute. Light never went off. Before putting the oil pan on I filled the oil pump and pickup tube to try and get oil in the pump.
The switch for the light is supposed to go out when it's above 2.1psi. If I do some math and assume a linear relationship between the speced RPM and pressures in the manual I should be able to get around 10psi while cranking.
I will probably try starting it and if the light doesn't go out within about 5 seconds I'll kill it.
Miles, Oil filter always gets filled up.
It was just an issue with priming. It wouldn't build pressure or flow at all. Finally got it to flow and build pressure on the starter by filling the pump through the where the oil pressure switch goes. Once I did that it built pressure just from cranking. Started it up and everything is fine.
I installed a rebiuld engine yesterday took 10 seconds for oil light to go out I do not crank them at all just fire it dont want to push all are assembly lube out cranking with no oil preshure is bad thing just fire it remember pump is trying to pull oil up hill and you dont make mutch rpms cranking
