disciplejohn52 Posted November 20, 2013 Share Posted November 20, 2013 93 legacy 2.2 wagon cruise control will engage and power the vehicle forward, but much lower than the set speed, and then only on flat or descending inclines. If I encounter a slight uphill, then it slows. Example: I set it at 45 MPH on a slight downhill, and it maintained it, but when I encountered an uphill portion of the road it slowed to 30 and stayed at thirty until the next downhill. At higher speeds (65 MPH) it won't maintain at all but will fall back to 55-60 even on flats or slight downhills. Thoughts? On a slightly unrelated note, the speedometer cable has recently(past 2 weeks) become noisy. Is it possible to lube, or should I just replace? The cruise issue is a year old, so I wouldn't think there's a correlation between the two, but... Link to comment Share on other sites More sharing options...
heartless Posted November 20, 2013 Share Posted November 20, 2013 the cruise issue sounds like it might be vacuum related - when was the last time you checked/replaced vacuum lines? old, hard, brittle vacuum lines wont hold as good a vacuum as new soft/supple ones will. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 21, 2013 Share Posted November 21, 2013 Sounds like its losing vacuum or the actuator servo isn't holding vacuum. Did you install the cruise? Does it use a vacuum pump or engine vacuum for the source? Link to comment Share on other sites More sharing options...
