DevoScoobyRoo Posted November 21, 2013 Share Posted November 21, 2013 Im looking to see if anyone has any awesome ways of repairing or re-sealing the gaskets on my t tops for my 86 brat. its seems they are leaking through the latch on the outer side. one on the locking latch as well in the middle. Id assume i could probably open them up and put sealant in there. but before i do that i am looking for the best ways to do it. Link to comment Share on other sites More sharing options...
pressingonward Posted November 21, 2013 Share Posted November 21, 2013 I unscrewed the latch mechanism from the T-top and used a little Permatex Ultra Black to seal it. Fixed the leak quickly and easily. Any RTV silicone should work fine. It's been a while so I don't quite remember what the leak path was, but I think it must have been around the bolts. Link to comment Share on other sites More sharing options...
coxy Posted November 21, 2013 Share Posted November 21, 2013 Do some research many Silicons are Acid Cure and you can smell it when you use them these can and do cause rust, What you want is known as Neutral Cure Silicon as it is not acid based curing system, It is also what you must use for sealing electrical connections for waterproofing to avoid corrosion issues, They even make what is known as Flowable Silicon for sealing Electrical components. Link to comment Share on other sites More sharing options...
DevoScoobyRoo Posted November 21, 2013 Author Share Posted November 21, 2013 awesome guys! USMB to the rescue once again! Link to comment Share on other sites More sharing options...
pressingonward Posted November 23, 2013 Share Posted November 23, 2013 Do some research many Silicons are Acid Cure and you can smell it when you use them these can and do cause rust, What you want is known as Neutral Cure Silicon as it is not acid based curing system, It is also what you must use for sealing electrical connections for waterproofing to avoid corrosion issues, They even make what is known as Flowable Silicon for sealing Electrical components. The only times I've run into acid cure silicone is in industrial applications and the tubes that come in Felpro gasket kits. Permatex does not state whether their products are acid cure or not, but they do not give off the sharp smell associated with acetic acid, and I have never seen them harm paint or cause rusting issues Link to comment Share on other sites More sharing options...
edrach Posted November 23, 2013 Share Posted November 23, 2013 Sometimes it's not a leaking gasket. When you remove a t-top it's just like a catch basin in the roof and the water needs to drain off. On the passenger side there's a drain hole which is there to drain off any extra water. Drain hole is just above the door pillar (right front) and that hole allows the water drain off in the front fender area. As old as some of our cars are, the drain is clogged. Run a coat hanger down the drain hole and and pour some water down it to be sure it drains properly. Repeat the process on the driver's side. Link to comment Share on other sites More sharing options...
Tat2Brat Posted March 18, 2014 Share Posted March 18, 2014 My T tops are leaking on the inner side of the top with the two pieces that slide into the slots water is sliding down the pseudo hinges and getting into the slots one side leaks into the cab the other side just holds the water If I take out all the bolts Silicone it and stick it back on wont I just be holding water in the slots and waiting for it to rust? I think im going to try to add a rubber strip above the slots so water avoids them completely But I dunno what do you guys think? Link to comment Share on other sites More sharing options...
