luko Posted November 21, 2013 Share Posted November 21, 2013 Quick question, I have a 2002 Subaru Outback sedan Automatic with the 3.0L but has a back read diff. and I was wondering if I could take a read diff out of a 2001 Legacy L which is also an automatic with the 2.5L and put it in the Outback. I know the bolts will match up I was just wondering about the gear ratios. I know that there's a difference between the Autos ans standards but wondering the same thing base models and Outbacks Link to comment Share on other sites More sharing options...
lmdew Posted November 21, 2013 Share Posted November 21, 2013 Get the #'s off the two transmissions and look up the gear ratios. There is a 2 letter code on top of the rear diff that provides the gear ratio but you have to pull the diff to see it. Larry Link to comment Share on other sites More sharing options...
Gloyale Posted November 22, 2013 Share Posted November 22, 2013 Should be a direct swap. If the outback was 4cyl it would be 4.44 but since it's a 6cyl it's 4.11. Legacy is a 4.11 so it should be a direct swap. You will need to take the spin on filter cap off the H6 trans and add it to the Legacy one. If not the spin on filter will hit the exhaust. Other option is to modify exhaust to clear filter. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 23, 2013 Share Posted November 23, 2013 On 11/22/2013 at 1:44 AM, Gloyale said: Should be a direct swap. If the outback was 4cyl it would be 4.44 but since it's a 6cyl it's 4.11. Legacy is a 4.11 so it should be a direct swap. You will need to take the spin on filter cap off the H6 trans and add it to the Legacy one. If not the spin on filter will hit the exhaust. Other option is to modify exhaust to clear filter. he said rear diff. But I think you still are confident the final ratios are interchangeable? Link to comment Share on other sites More sharing options...
luko Posted November 23, 2013 Author Share Posted November 23, 2013 I would like to confirm that the ratios are the same before I get them swapped around and burn that viscus clutch out, lol Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 25, 2013 Share Posted November 25, 2013 I think you will need to spin the donor rear diff to confirm the ratio. Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 25, 2013 Share Posted November 25, 2013 What makes you think the rear diff is bad? They very rarely fail, and often people think that binding and thumping in the drivetrain when cornering tightly is a failing rear diff when it's actually the rear transfer clutch in the transmission. Does your car have VDC? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 25, 2013 Share Posted November 25, 2013 On 11/25/2013 at 6:03 PM, WoodsWagon said: What makes you think the rear diff is bad? They very rarely fail, and often people think that binding and thumping in the drivetrain when cornering tightly is a failing rear diff when it's actually the rear transfer clutch in the transmission. Does your car have VDC? excellent question! sometimes folks have bad bushings, bad u-joints or carrier bearings too. Al stuff that 'could' be confused with a bad rear diff I suppose. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 26, 2013 Share Posted November 26, 2013 (edited) the 3.0 final drive ratio is 4.11 the 2.5 legacy L auto trans final drive ratio is 4.11. they are a match. just like gloyale said. but what is wrong with your car? Edited November 26, 2013 by johnceggleston Link to comment Share on other sites More sharing options...
ivans imports Posted November 26, 2013 Share Posted November 26, 2013 In 18 years and hundreds of subarus only ever seen two bad rear diffs very rare to fail and when they do its catastrophic you whould know Link to comment Share on other sites More sharing options...
luko Posted November 26, 2013 Author Share Posted November 26, 2013 What she is doing is vibrating like a bitch when you hit around 30 MPH, I have diagnosed a couple of re-ends before and that what it seems to be, not sure though..The reason I'm asking is because I found a 2002 outback sedan with the 3.0 and every option with 176,xxx miles on it and it's only $1,500, I know this guy, and I was just tying to figure some stuff out in case I buy this car.. and the car does have VDC Link to comment Share on other sites More sharing options...
ivans imports Posted November 27, 2013 Share Posted November 27, 2013 Check driveshaft ujionts Link to comment Share on other sites More sharing options...
