Luvn737s Posted November 22, 2013 Share Posted November 22, 2013 I have no operative dash gauges on my 85 GL Wagon. Is there any common connection to all the gauges? The lights in the dash and idiot lights work. R2 Link to comment Share on other sites More sharing options...
Cougar Posted November 22, 2013 Share Posted November 22, 2013 There is most likely a common power source for the gauges. Always verify all the fuses are good when having this kind of trouble. Using a test light probe to verify power is getting to both sides of the fuse is the best way to do that. Place the probe tip on each of the two slits on top of the fuse and each side should light up. Link to comment Share on other sites More sharing options...
jonas Posted November 22, 2013 Share Posted November 22, 2013 Has the cluster been removed at any time? Link to comment Share on other sites More sharing options...
Luvn737s Posted November 23, 2013 Author Share Posted November 23, 2013 I just got the car and I don't know if they had it out or not. No fuses were blown, but I don't know about power coming in, I'll check. Also, the radio is dead and the A/C gets no power. Fan blower, interior lights, tach and wipers work. I'm guessing it's something on the engine side of the firewall, but that's only a guess. Link to comment Share on other sites More sharing options...
Cougar Posted November 24, 2013 Share Posted November 24, 2013 Check the fusible links inside the box mounted on the coolant reservoir and make sure they are okay and making good connection. Link to comment Share on other sites More sharing options...
Luvn737s Posted November 24, 2013 Author Share Posted November 24, 2013 The Fusible Links look OK and check OK on the meter. I was hoping to find a big harness bundle that heads to the gauge cluster, but no luck yet. Link to comment Share on other sites More sharing options...
Cougar Posted November 24, 2013 Share Posted November 24, 2013 My info for a 88 model shows fuse 12 supplies power to the gauges and your model is most likely uses the same fuse. The fuse also supplies power to the door warning lights so they work the fuse is most likely okay and power is getting through. Even though a fuse is good it is good to make sure power is getting to it also if that is in question. If that is okay then you need to look for a connection problem between that fuse and the dash panel itself. My info shows that a red/yellow wire comes from fuse 12 and connects to a black/white wire and that goes to the dash panel to power the gauges. Link to comment Share on other sites More sharing options...
Luvn737s Posted November 25, 2013 Author Share Posted November 25, 2013 I checked the canon plug by the coil which seems to carry all the engine sensors and it appears to be getting 12 V through the key. The fuses all get 12 V and the ground is good. The radio is getting 12V and the ground is good. There is a gold box under the steering column that has a red flashing light on it. If it is flashing an OBD code it would be code 12. I will look specifically at the fuse 12. Thanks! Link to comment Share on other sites More sharing options...
Cougar Posted November 25, 2013 Share Posted November 25, 2013 I think your problem is under the dash area and not under the hood. Code 12 has to do with the ignition switch. The gold box is the ECU unit. Link to comment Share on other sites More sharing options...
Luvn737s Posted November 28, 2013 Author Share Posted November 28, 2013 (edited) I get an ECS light on the dash. At least that works! Is there a ground common to the cruise control, radio, and dash gauges*? Or maybe there was a major electrical zap sometime in it's past that fried everything. *Fuel gauge appears to work as it reads full when it's full, but haven't driven it enough to know if it fails to the "Full" indication. Edited November 28, 2013 by Luvn737s Link to comment Share on other sites More sharing options...
SmashedGlass Posted November 28, 2013 Share Posted November 28, 2013 (edited) You may want to go to the trouble of removing your cluster, and making sure that everything is in fact plugged in, yourself. As there is no telling whether the PO had pulled it or not, it could be something is loose or fully unplugged. There are two rectangular plugs on top of the cluster, and two round ones that are behind it. Here is an excellent writeup on how to do this procedure: http://www.ultimatesubaru.org/forum/topic/131336-led-retrofitting-on-instrument-cluster-dashboard-removal-procedures/ But, Jezek's bandwidth for the photos gets exceeded each month rather rapidly so right now, the pics aren't there Plug the address above into a proxy site like hidemyass.com and the pictures will show. Edited November 28, 2013 by SmashedGlass Link to comment Share on other sites More sharing options...
Luvn737s Posted November 30, 2013 Author Share Posted November 30, 2013 Found a break in the circuit board and after fixing it, she works great. Now onto the abysmally poor performance! Link to comment Share on other sites More sharing options...
Cougar Posted November 30, 2013 Share Posted November 30, 2013 Thanks for the update. Link to comment Share on other sites More sharing options...
