vibration/shudder under 20 mph from a stop
I have a 2000 Legacy GT manual transmission, over the past several weeks my car has this horrible shudder/vibration when going from a stop or slow roll. It stops once I hit 20 mph. It is getting increasingly worse and no matter how slow or fast I take off it still does it. What do I do and what could it be?
Pull down the heat shield in the middle of the car and see if the center support bushing is messed up.
The shop could have bolted the support bearing bracket on upside down and thrown off the driveshaft angle which will wear out the bushing very quickly.
Also check the 4 bolts that secure the two halves of the driveshaft together at the flange by the support bearing, and the 4 bolts that secure the driveshaft to the rear differential flange. Make sure they're all tight.
