86 GL Turbo Not Idling
Alright, so I finally made the purchase of the 1986 GL coupe, however it seems like it doesn't want to idle now, even though it ran perfectly two weeks ago. I have to give it throttle or it will die. It's also running rich, but it was doing this two weeks ago as well. So far I've heard that the MAF and IAT sensors might be dirty and that it might be a vacuum leak. Any other ideas?
What makes you think it is running rich?
What does the O2 sensor have to say on the subject?
Based on your brief description,I`d bet money it is lean.
Dirty IAT sensor causing problems is unheard of,
Bad MAF is almost as unlikely,
Turbo right?
My money is on an unmetered air leak from the rubber intake tract/associated plumbing or PCV system.
Or a vacuum leak.Put a gauge on it,
I would inspect the CTS cnnector for corrosion as well.
On the GL10's, there is an idle screw adjustment, on the back side of the round intake inlet into the top of the intake manifold.  The screw access is from the top.  Counterclockwise is a higher idle.  However, you should check the timing first.   If the advance slips to less than specified, the idle rpm also drops.  The bolts that hold the distributor in place and at the correct advance, may be loose.
I can tell it's rich by the smell. Also, it currently has an exhaust leak in the downpipe. I assume there's an O2 sensor before or after the cat, could that be causing issues as well? Oh, and another note. Once I get moving it's running perfectly fine. When I started it this morning it did something a bit differently. It idled at 1000rpm for a little bit, slowly idled higher to about 1300rpm, and then slowly idled down until it died.
Edited by Ziginox
Upstream exhaust leak could indeed cause rich running once the O2 sensor warms up.
Try it w/O2 disconnected.
The fact that it is an idle problem suggests leaness is more likely though.
I wish I had a nickel for every customer who incorrectly thought he could detect mixture strength w/his nose.
I'm not the only one that noticed the smell, my friend (who is an experienced mechanic) is the one that originally pointed it out to me. It's a bit late now, but tomorrow I will go out and see if I can disconnect the O2 sensor.
Edited by Ziginox
No, he was only thinking MAF sensor due to the richness, and that the richness might be causing idle issues. The air filter was also slightly oily, which is another reason he thought that. I think that someone that assembled a Corvair from parts that had been sitting for years in a few days and drove it home, as well as rebuilding the engine in his truck (just to name two) should know his stuff.  :P
Edited by Ziginox
I like Naru's idea of putting a vacuum gauge on it, if for no other reason that I like to eliminate the easy/cheap stuff first.
Not sure if you've done this yet, but pulling a plug or two can also give you an idea of how the mixture is doing.
Not sure if you've done this, but a timing light would show if it's advancing properly. If it has a vacuum advance with a bad diafram, that could be a big vacuum leak.
Just a couple thoughts...
John
It's unlikely that there's an exhaust leak that's messing with your o2 sensor reading, unless its the turbo/downpioe gasket. The o2 sensor is a couple inches past the turbo, most leaks are past that. X2 on pulling a plug to see what they look like. If it starts fine when cold then goes to spoob after, it's probably one of your sensors. It's running a set fuel map when cold then looking to your sensors to determine fuel ratios after the coolant temp sensor says its warmed up. So, o2 or MAF, maybe even the coolant temp sensor. Clean the MAF, and the others are super cheap on rockauto. Oil in your air filter makes me think the MAF is dirty.
  On 11/26/2013 at 10:50 PM, mr sarcastic said:
If your exhaust is leaking before your o2 sensor, it'll cause the motor to run lean.
You have it backwards my friend.
O2 sensor will see extra O2(that never went through the engine) from the leak  causing the computer to THINK the motor is lean and add extra fuel resulting in an intake mixture that is too RICH.
Edited by naru
Well, as mr. sarcastic said, the O2 sensor is just a few inches past the turbo, where the exhaust leak is farther downstream.
EDIT: I forgot to mention that I check the distributor cap and it wasn't loose, or is the advance adjusted internally?
Edited by Ziginox
  On 11/27/2013 at 8:46 PM, jono said:
injected and no one has suggested dirty injector(s) ?? If they don't spray nice, fuel don't burn nice or at all and possibly makes it rich exhaust beyond control of O2 sensor fuel trim range.
We dumped some injector cleaner in to no avail, but still they could still be gunked up...
The distributor timing advance wears out because on the 86, the vacuum from the engine causes one distributor plate to rotate relative to a plate below it.  Ball bearings separate the plates.  The bearings get corroded and pitted, dirt gets piled up on the bearing path and/or a gough gets ground into the bearing path.  This bearing path area needs to be cleaned and inspected.  If there is impedence to the plate rotation, then the timing advance will be off.  Upon release of your gas peddle, the timing advance may get hung up at a more advanced position. Or upon application of more gas, the engine may get hung up at a less advanced position than it should be.  More advanced positions normally cause the engine to idle faster, not slower.  I have not seen a reply here where the timing was checked, because that will cause a a low idle rpm.  The idle mixture needle will also cause a low idle rpm, by turning it clockwise.  The throttle cable can be used to adjust idle higher.  If the engine is not idling smoothly no matter what rpm you are above say 800 rpm, then you have bigger problems.
  • 2 weeks later...
Well, it is indeed the MAF sensor. I tried running it with the sensor unplugged and it idled perfectly. I can't get it apart to clean the sensor though as I can't get the airbox apart because the intake boot becomes rather solid at 14 degrees (-10 for the people in smart countries.)
