Capcom Posted November 25, 2013 Share Posted November 25, 2013 Hey guys, I have a 1986 GL-10 and my water pump just went out. I called the ol' Napa and they're asking which hub height I need, I can't find anywhere what the stock hub height is and I figured that if there was anyone I could trust, it was you beautiful people. Thanks so much! Link to comment Share on other sites More sharing options...
NorthWet Posted November 25, 2013 Share Posted November 25, 2013 Check out this thread, particularly post#6: http://www.ultimatesubaru.org/forum/topic/142209-water-pump-has-me-confused/ Link to comment Share on other sites More sharing options...
ruparts Posted November 25, 2013 Share Posted November 25, 2013 hi, its just my opinion but take it down with you and match it,, if its not the one then you need the other one,, 1 is 110mm height,, the other is 105mm height , that is the only two they used,, otherwise they are the same, that is except one has bolt holes and one has studs where the fan and pulley fits,, and you can add or remove the studs. 1 Link to comment Share on other sites More sharing options...
Gloyale Posted November 26, 2013 Share Posted November 26, 2013 86 gl-10 you want the 105 mm Link to comment Share on other sites More sharing options...
Capcom Posted December 5, 2013 Author Share Posted December 5, 2013 (edited) Got everything sorted out, it is the longer one. There's a good video to watch if anyone ends up needing to do this and has no clue where to start. http://www.youtube.com/watch?v=BHXOtGNw3_Q Only difference really is that on the 86 Turbo, there are seven bolts you need to take out of the pump (I was freaked out when I took five out then still couldn't remove the pump). The hidden two are behind the timing belt cover, luckily you can remove the right side of it without having to remove the entire cover and just work around the remaining part it. My ol' girl is up and running again, very happy. Thank you all for the help! Edited December 5, 2013 by Capcom Link to comment Share on other sites More sharing options...
