86subaru Posted November 27, 2013 Share Posted November 27, 2013 How or where is the plug to put in the code reader? Car runs fine Link to comment Share on other sites More sharing options...
topsecret Posted November 27, 2013 Share Posted November 27, 2013 it's obd1. there should be two sets of connectors under the steering column that are unplugged, one green, one black plug in the black with the car turned off then turn the key so the power is on without starting the car. the check engine light will flash at you long flashes are first digit of the code short flashes are second digit then look up the code you've just discovered Link to comment Share on other sites More sharing options...
topsecret Posted November 27, 2013 Share Posted November 27, 2013 http://www.surrealmirage.com/subaru/engine.html this link goes through the process really well. Link to comment Share on other sites More sharing options...
86subaru Posted November 27, 2013 Author Share Posted November 27, 2013 Thanks Link to comment Share on other sites More sharing options...
86subaru Posted November 29, 2013 Author Share Posted November 29, 2013 Can not seem to find black wire. What color does black wire plug into Link to comment Share on other sites More sharing options...
Gloyale Posted November 29, 2013 Share Posted November 29, 2013 (edited) Green and Black connectors, not wire colors. They will be up under the dash, Slightly left of the column. Possibly taped with masking tape to the wiring loom that goes into the ECU (computer box under dash) Green connector wires will be orange wire at one side and Black/Red(ground) at the matching one. Black connectors wires will be Red/Black and the match will again be Black/Red(ground) If you can find the Orange wire in the green connector, and the Red/Black wire in the black connector.....you can simply ground them anywhere if you can't find their matches Edited November 29, 2013 by Gloyale Link to comment Share on other sites More sharing options...
86subaru Posted November 29, 2013 Author Share Posted November 29, 2013 Ok after reading code is it possible to clear code Link to comment Share on other sites More sharing options...
86subaru Posted November 30, 2013 Author Share Posted November 30, 2013 Long long short short Link to comment Share on other sites More sharing options...
86subaru Posted November 30, 2013 Author Share Posted November 30, 2013 Ok knock sensor. Code 22.could this be a old ghost code in memory?? Link to comment Share on other sites More sharing options...
86subaru Posted November 30, 2013 Author Share Posted November 30, 2013 Changed it o ut with good one.the old one was really cracked never changed Link to comment Share on other sites More sharing options...
Gloyale Posted November 30, 2013 Share Posted November 30, 2013 Nah, probably is for real. Easy to replace. takes 10 mins. Just need a 12mm socket on a long extension and a good flashlight. Once you fix it....to clear codes connect both sets of connectors, and start engine, run it 40 secs or more and drive it a few MPH forward/back.....when the light flashes codes are clear. If it keeps giving you a code there is still a problem once all are fixed it will clear codes. Link to comment Share on other sites More sharing options...
86subaru Posted December 1, 2013 Author Share Posted December 1, 2013 Got it thanks Link to comment Share on other sites More sharing options...
