AdventureSubaru Posted November 28, 2013 Share Posted November 28, 2013 Got a trans from pick n pull today from a 99 OBS that I'll be putting in soon after the new clutch arrives. Visually it looked pretty good. The car it came from seemed well maintained and was involved in a front end collision. (Following the rule that it probably drove itself to the accident) No leaks. The gear oil smells good and is still honey colored. (I take that as a good sign) No wiggle to the shaft inside the bellhousing. trans is about 180k. I've swapped a few trannies, but done no real work to one. Anything else I should do/check before I install it and cross my fingers? Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 28, 2013 Share Posted November 28, 2013 Make sure it engages all the gears. You've pretty much covered everything else. Link to comment Share on other sites More sharing options...
