beerdoctor Posted November 30, 2013 Share Posted November 30, 2013 I need new struts. I'm already running a slightly larger tire size than stock and they rub when turning sharp. I'm assuming outback struts will do the trick? Do I need to get new springs, mounts, etc...? What years and models work for the swap? I appreciate any help and advice! Link to comment Share on other sites More sharing options...
AdventureSubaru Posted November 30, 2013 Share Posted November 30, 2013 Welcome to the board! Any of the 96-99 Legacy Outback struts will be a direct bolt in for 1-2 inches of lift. The front struts/springs from a 2000-2004 outbacks are also the same but not the rears. You can get another inch or so using Forester Struts/springs. Do a few searches on here, members rides and in the off road section. It's been done many times with great results and plenty of before and after pics and some good write ups. Link to comment Share on other sites More sharing options...
heartless Posted November 30, 2013 Share Posted November 30, 2013 My 95 with a straight Forester strut swap - did the complete assembly (strut, spring, & tophat) - sitting next to my "stock" 90 - a fair difference between the two. Link to comment Share on other sites More sharing options...
bratman18 Posted November 30, 2013 Share Posted November 30, 2013 They will swap right in as long as you change the rear top hats over. Only the 95-99 have the same top hat bolt pattern, the 1st gen Legacys were different in the rear. Link to comment Share on other sites More sharing options...
ivans imports Posted November 30, 2013 Share Posted November 30, 2013 I put outback struts in my 98 outback sport the rear pattern on top was diferent so I sloted the holes had to bang the body in slightly on rear to fronts drop in lifted it about 3 inchs with the biger tires On the rear I had to use trailing arrn front bracket from outback to get arm to drop and get alinment right Link to comment Share on other sites More sharing options...
beerdoctor Posted November 30, 2013 Author Share Posted November 30, 2013 Thank you all for your replies! Here's my list so far. This is all 99 forester stuff. A set of 4 struts(sensen 1640) A set of rear springs (moog 6435), front and rear strut mounts (I'm assuming this is what you are calling tophats?). I still need to find front springs? and this will all bolt on my 90? Link to comment Share on other sites More sharing options...
