jonas Posted November 30, 2013 Share Posted November 30, 2013 Rockauto is listing just a u-joint, then it has a rear u-joint listed. I know these are used for different vehicles so im thinking that I don't need a rear specific joint. My rear is fine but going to replace both since i'll have it out anyways. Link to comment Share on other sites More sharing options...
jonas Posted November 30, 2013 Author Share Posted November 30, 2013 I'm starting to wonder about the imput shaft bearing. I see a bit of leakage and suspect it would give the same symptoms as a bad u joint? It is a swapped in 5 speed. Link to comment Share on other sites More sharing options...
bratman2 Posted December 3, 2013 Share Posted December 3, 2013 (edited) If my memory is correct when I replaced my U-joints the front and back were the same! On a 87 Brat! Rear was shot but why go through the trouble to replace one when the other will be next! Edited December 3, 2013 by bratman2 Link to comment Share on other sites More sharing options...
odie Posted December 3, 2013 Share Posted December 3, 2013 I think front & rear are the same...it's that way on most, if not all driveshafts that I've encountered Link to comment Share on other sites More sharing options...
