Crowdaddy406 Posted December 5, 2013 Share Posted December 5, 2013 I recently bought an XT6 from my older brother and took it to a mechanic because I have no place to work on it. He claims it has a broken drive shaft but it has been 2 months since I heard anything about parts. Does anyone know where I might be able to find one or what other models would match? Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 6, 2013 Share Posted December 6, 2013 The driveshaft from the transmission to the rear diff is the same for all '85-89 4wd cars with a two piece driveshaft (and Loyales from '90-'94). The higher end turbo cars and the XT6 had a rubber dampener built into the front portion of the driveshaft but the ones without don't seem to have an issue from what I recall. Now if you're referring to the axle shaft, also known as a half shaft for an axle, then those are XT6 specific for the fronts. The rears are interchangeable with all 4wd Subarus from '85-89 and Loyales from '90-'94. Hope this helps. Link to comment Share on other sites More sharing options...
rain_man_rich Posted December 9, 2013 Share Posted December 9, 2013 If it's the front, here's an option: http://www.ultimatesubaru.org/forum/topic/142870-1-new-xt6-front-axle-35/ Link to comment Share on other sites More sharing options...
