naru Posted December 14, 2013 Share Posted December 14, 2013 Testing purposes?? That is what a gauge is for. Used pumps are in the same catergory as used toilet paper as far as I am concerned. Measure volume w/a quart jar. You are making this more difficult than it needs to be. Link to comment Share on other sites More sharing options...
travmo86 Posted December 14, 2013 Author Share Posted December 14, 2013 I never mentioned a used fuel pump. I did mention a used fuel pressure regulator if need be. The link I posted is for a new pump. For the price just switch the pump being its 20 years old. Not expensive nor............difficult at all in my opinion. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 14, 2013 Share Posted December 14, 2013 Volume is fine if the pump holds pressure under load. < the reason you drive the car with the pressure guage hooked up is to see if fuel pressure drops off. If pressure drops its because pump cant move enough volume to keep pressure up. Rent a pressure guage from the auto parts store if you don't have one. Link to comment Share on other sites More sharing options...
travmo86 Posted January 18, 2014 Author Share Posted January 18, 2014 Just an update: found a local garage that is able to data stream a 1993. The cam sensor and crank sensor were not in sync. On further inspection found the crank pulley bolt had backed out slightly. The crank gear notched out the key slot in the crankshaft causing the timing to be all over the place. The engine is done. Thank you to everyone for the help! Link to comment Share on other sites More sharing options...
ivans imports Posted January 18, 2014 Share Posted January 18, 2014 A 2.2 is never done I fix this all the time takes some effort but can be fixed very common problem a new gear Key and crank pulley some locking compound and a peen hammer takes me about 1.5 hours to fix Link to comment Share on other sites More sharing options...
