GAS Posted December 8, 2013 Share Posted December 8, 2013 Hope I am in the correct section Hello all, on Thursday the river Tweed burst its banks and left my Legacy 2y.0 GL in 400 mm of water. The exhaust was full of water air intake was dry ecu was wet and elec connections in engine bay look dry sprayed with water repellent and left, charged battery and tried to start, engine spins ok smell of petrol at exhaust but no spark. any ideas Link to comment Share on other sites More sharing options...
lmdew Posted December 8, 2013 Share Posted December 8, 2013 Did you pull the ECU connector and dry and clean it. I'd suspect the ECU is damaged if the water was up to that level. Start with the connectors and sensor connectors. Link to comment Share on other sites More sharing options...
GAS Posted December 8, 2013 Author Share Posted December 8, 2013 (edited) Yes some pins in ecu damaged and looks like tracking marks across other pins, new ecu required thanks. Can anyone help need ecu 22611 AH240 thanks Edited December 8, 2013 by GAS Link to comment Share on other sites More sharing options...
ivans imports Posted December 8, 2013 Share Posted December 8, 2013 Did you try washing out the boards on ecu blow it out and try again or is it burnt I may have ecu will look Link to comment Share on other sites More sharing options...
GAS Posted December 8, 2013 Author Share Posted December 8, 2013 (edited) Some of the pins were damaged, don't know if it was due to the flood or have corroded and snapped when I pulled the plugs out, when I come back next week I was going to try solder new pins in and try again thanks Ivans Edited December 8, 2013 by GAS Link to comment Share on other sites More sharing options...
