86subaru Posted December 8, 2013 Share Posted December 8, 2013 Bought 91 fwd legacy sedan fans do not turn on.but no overheating temp goes to center idle or driving and yes 20 degree outside. Any suggestions?? Link to comment Share on other sites More sharing options...
Gloyale Posted December 8, 2013 Share Posted December 8, 2013 Plug in the green diagnostic connectors under the steering column. The fans should cycle in time with the fuel pump, and check engine light. This is Test mode, and will output any present/current trouble codes too. But it's also handy for testing fans and fuel pump operation. Link to comment Share on other sites More sharing options...
MilesFox Posted December 9, 2013 Share Posted December 9, 2013 IF the temp sensor is unplugged, the fans will run continually. If you decided to unplug it to test it, or change it as routine maintenance Link to comment Share on other sites More sharing options...
86subaru Posted December 9, 2013 Author Share Posted December 9, 2013 Ok thanks Link to comment Share on other sites More sharing options...
86subaru Posted December 9, 2013 Author Share Posted December 9, 2013 The temp sensor is pluged in Link to comment Share on other sites More sharing options...
86subaru Posted December 10, 2013 Author Share Posted December 10, 2013 Got real cold out. Will check Link to comment Share on other sites More sharing options...
86subaru Posted December 10, 2013 Author Share Posted December 10, 2013 Seems like it takes a long time to heat up.coolant is set up at -30 heat is not real hot temp gauge is 1/2 way possible thero stat? Link to comment Share on other sites More sharing options...
MilesFox Posted December 10, 2013 Share Posted December 10, 2013 There may be an air pocket in the heater core. Add coolant to the upper radiator hose. BE aware of any leaks (water pump) or coolant pushing out of the overflow. Sounds like low enough coolant for the heat to get weak, but not enough to overheat. This would explain the fans not coming on if there is an air pocket around the CTS. The CTS controls the fan, and the gauge is a separate sensor like an ea82 Link to comment Share on other sites More sharing options...
Frank B Posted December 10, 2013 Share Posted December 10, 2013 (edited) It's possible that your heater core is partially plugged as well. If it was warmer out, I'd suggest connecting a garden hose to your heater core to flush it. As mentioned above, an air pocket in your cooling system can cause a lot of problems. I've learned to disconnect one end of one of the heater hoses and turn it up so it's almost as high as the radiator neck. Then slowly pour in coolant so the air can escape form the heater hose. Once coolant starts to come out of the heater hose, or heater core end, stop and hook it all back up. Sometimes there will still be air in it, and you'll know when the temp climbs above normal when you first start and idle the engine. If it does climb, just shut it down and walk away until it cools off, once it does and the rad cap is removed that air usually escapes. Sometimes squeezing the rad hoses, with the rad cap on and system closed, to "pump" the coolant around will move the air so it can find it's way to the rad cap. Is it possible that the rad itself isn't getting hot enough with the cold temps outside? Where's the fan switch on that year Legacy? If the engine is hot and the rad is not, you may have a clogged radiator or bad water pump. The impeller can rust away if the coolant system hasn't been maintained over the years. Installing an aftermarket temp gauge to see exactly what the temp is may be the way to go too. Edited December 10, 2013 by Frank B Link to comment Share on other sites More sharing options...
86subaru Posted December 12, 2013 Author Share Posted December 12, 2013 Ok thanks Link to comment Share on other sites More sharing options...
Bushwick Posted December 13, 2013 Share Posted December 13, 2013 Dunno if the 91' is much different than a 95', but if it has AC (even if the belt is removed or AC compressor is omitted) turning the AC on in-car should kick the fans on for quick reference. Also, (at least on my 95') turning on front windshield defrost (selecting the defrost button ONLY) will also kick the fans on, but I'm assuming this is only on AC equipped cars. Makes for super quick fan ON tests and emergency "fan ON" scenarios, which is nice. Link to comment Share on other sites More sharing options...
zedhead Posted December 15, 2013 Share Posted December 15, 2013 Both of my Suby's run with the guage showing half way. Link to comment Share on other sites More sharing options...
Bushwick Posted December 15, 2013 Share Posted December 15, 2013 Mine sits at the halfway mark too. This car also heats up incredibly fast too. It's been around mid teens to low 20's. Start it up, idle for about a minute, drive off (I keep RPM's low until it's more warmed up so just baby it for a couple miles) and within 1.5-2 miles it's nearly at the halfway mark and blowing nice, warm air. So glad I bought mine as a winter vehicle instead of a Ford Ranger 4x4. Link to comment Share on other sites More sharing options...
