Luvn737s Posted December 10, 2013 Share Posted December 10, 2013 Do EA82's with oil pressure gauges also have an oil light? Link to comment Share on other sites More sharing options...
Gloyale Posted December 10, 2013 Share Posted December 10, 2013 No it's either or although the senders each mount to different locations on the oil pump so it would be easy to add a switch and light to a car with a gauge already. Adding gauge to car with only light???......not so much easy but doable. Link to comment Share on other sites More sharing options...
Luvn737s Posted December 10, 2013 Author Share Posted December 10, 2013 No, the manual shows an annunciator light below the cluster that holds a gauge. Link to comment Share on other sites More sharing options...
Gloyale Posted December 11, 2013 Share Posted December 11, 2013 The blank place for the light is present on all EA82s. But there is no switch to trip it and likely not actually a bulb/holder in the cluster. You'd have to run a seperate wire because none of them had both. Add the wire and bulb to the cluster and switch to the pump, and you could easily have both functioning light and gauge. Link to comment Share on other sites More sharing options...
Luvn737s Posted December 11, 2013 Author Share Posted December 11, 2013 I see that there are spots for AT trans temp, lift gate and a few others I can't decipher, but if they are supposed to be blank, I'll leave them. Link to comment Share on other sites More sharing options...
