IMPREZA425 Posted December 10, 2013 Share Posted December 10, 2013 I have a 2002 impreza outback wagon I been having trouble with the driver side head light connector being fried. I have read that it is a common problem does anyone know what causes this or how to fix it?? I have spliced in another connector but it is doing the same thing. Here is the pix of the connector. So what I have done before all of this I have Installed an HID kit. But it was kind of finiky because sometimes the HID kit wouldnt make my fog lights work. I would have to press the fog light button couple of times before it does work. So i disconected the HID kit completely only to find out the connector to the HID was fried. Then i put back in the stock bulbs and has worked for a while then same thing happened my connector melted on the inside then i spliced in another connector and the same thing is happening. This is what my connector is doing in the pic. PLZ PLZ PLZ HELP Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 10, 2013 Share Posted December 10, 2013 Suspect that the HID light kit is pulling more amps then a stock set up. As a result, the extra current pull is heating up the connector and frying it. Suspect the stock connector is not up to the task of an HID. I don't have a solution, but am thinking that some auto companies may sell their cars with stock HIDs. If so, source one of their connectors from a dealership, or a wrecking yard. It is possible, that who sold you the HIDs, may have bulb connectors as well to solve the problem. You can't be their only customer to have this problem. Quote Link to comment Share on other sites More sharing options...
fishy Posted December 11, 2013 Share Posted December 11, 2013 I had this happen so many times in my 99 Legacy (with 100% stock headlight configuration) that I actually used to carry a spare socket and bulb in the car.Make sure you've got good connections and good grounds in the area. Once that connection has melted the pins on the other end are probably contaminated and nasty so clean those up before installing a new end.Also: before I retired my 99 I was looking around and was able to find some heavy duty versions of those plugs on ebay (I think). The parts store ones I had been using were pretty cheap and flimsy looking. Might want to look for heavy duty plugs to use instead. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 11, 2013 Share Posted December 11, 2013 Use pliers or something small to get into the plug and squeeze the terminals back together so they have a tight fit against the connector that comes off the bulb. Then put some dielectric grease into the plug. Quote Link to comment Share on other sites More sharing options...
lneulicht Posted December 12, 2013 Share Posted December 12, 2013 Am I the only driver who finds high intensity headlamps anti-social? Heavy duty nylon sockets are available to handle the extra heat. I'd recommend Rockauto but they are not in my good graces at the moment. Quote Link to comment Share on other sites More sharing options...
