ehanes7612 Posted December 13, 2013 Share Posted December 13, 2013 My distributor wont advance when ignition is turned on..when i manually turn the crankshaft counter clockwise (wrong way) , distributor turns, but when I manually turn it the right way (clockwise ) distributor doesn't turn. Took distributor out and it seems fine..turns just fine..so I figure it's something to do with the camshaft..before I remove the valve cover..does anyone know what could be broken? Link to comment Share on other sites More sharing options...
ehanes7612 Posted December 13, 2013 Author Share Posted December 13, 2013 sorry ..1990 subaru loyale Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted December 14, 2013 Share Posted December 14, 2013 Your gear has to be broken on the rocker cover. In my humble opinion. Link to comment Share on other sites More sharing options...
MilesFox Posted December 14, 2013 Share Posted December 14, 2013 inspect fro broken tming belt, or teeth missing on the timing belt. The belt drives the cam, which drives the distributor. I'll be there are teeth missing on the belt near the crank snout. 1 Link to comment Share on other sites More sharing options...
ehanes7612 Posted December 14, 2013 Author Share Posted December 14, 2013 Your gear has to be broken on the rocker cover. In my humble opinion. thats what I am thinking too , thanks 1 Link to comment Share on other sites More sharing options...
