nick1208 Posted May 1, 2014 Author Share Posted May 1, 2014 On 5/1/2014 at 7:21 PM, kirzick said: Hate to bother you. Although the picture was helpful, if you have time can you post actual measurements of that diff plate? Also do the spacers toward the front of the diff get tightened down or do they stay loose? Thank you! Don't have any measurements on it but they do get tightened and it drops my diff 3 inches Link to comment Share on other sites More sharing options...
kirzick Posted May 1, 2014 Share Posted May 1, 2014 Okay thank you i can work from there! Link to comment Share on other sites More sharing options...
Subruise Posted May 1, 2014 Share Posted May 1, 2014 tighten them, dont ever leave suspension parts loose. if you want measurements, go outside w a tape measure. measure how far apart the holes are and decide how far down youre going ( ie how big is your lift?) put the bottom holes there. make sure your piece of material is big enough for that. maybe start a thread of your own and for others if you have questions. diff drop is the simplest lift part by far, you literally just need to keep it all the same. so if you used a 1000 inch drop, youd drop the front of the diff the same 1000 inches. its just moving holes around. 2 Link to comment Share on other sites More sharing options...
ystrdyisgone Posted May 2, 2014 Share Posted May 2, 2014 There is another option you know.. Take the car to school, and tell the people who wanna use you for your car to F off.. or phrase it however you would like to get the point across. 3 Link to comment Share on other sites More sharing options...
kirzick Posted May 2, 2014 Share Posted May 2, 2014 On 5/1/2014 at 8:24 PM, Subruise said: tighten them, dont ever leave suspension parts loose. if you want measurements, go outside w a tape measure. measure how far apart the holes are and decide how far down youre going ( ie how big is your lift?) put the bottom holes there. make sure your piece of material is big enough for that. maybe start a thread of your own and for others if you have questions. diff drop is the simplest lift part by far, you literally just need to keep it all the same. so if you used a 1000 inch drop, youd drop the front of the diff the same 1000 inches. its just moving holes around. Makes sense. i just didnt want to break something. thanks 1 Link to comment Share on other sites More sharing options...
nick1208 Posted May 16, 2014 Author Share Posted May 16, 2014 Got wet today! went out with Doug and Kevin. Got stuck in this position. notice me in the back. lol. Broke the shop vac out. Was originally going to take the carpet out, but im going to try to keep that as long as possible. Link to comment Share on other sites More sharing options...
SmashedGlass Posted May 16, 2014 Share Posted May 16, 2014 Lol, from my experience, let me tell you.....that carpet is going to stink. The jute padding underneath NEVER dries, and will start to mold and mildew. I had to remove my carpet, rip all the padding off, and replace the padding with new after a persistent windshield leak that I didn't notice because I wasn't driving mine regularly. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted May 16, 2014 Author Share Posted May 16, 2014 Yeah, I used the shop vac. Hopefully I got enough out. Haven't been down this morning, but i cracked the windows so hopefully it isnt too bad. It's been hot lately. Link to comment Share on other sites More sharing options...
NorthCoast Posted May 16, 2014 Share Posted May 16, 2014 Got some tools out of my car this morning and had some water pooled up myself. Glad my carpet is long gone. Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 16, 2014 Share Posted May 16, 2014 He's right.. It neverdries I actually had plants bloominginside in a garage...its gonna stink. Sorry nick but you may have to pull it out..or you can pull it out just to keep it.. It does come out in one piece Link to comment Share on other sites More sharing options...
SmashedGlass Posted May 16, 2014 Share Posted May 16, 2014 I'd pull it, Nick. Unless you live somewhere completely arid, like Arizona-Nevada-SoCal, the padding will never dry out. It isn't that hard (except getting it from behind the blower motor housing--I cut mine to alleviate that problem), and you'll be able to salvage the carpet itself. As to the padding, I replaced mine with some Ultratouch Radiant Barrier that I picked up at Home Depot, it's like the jute padding but has an aluminized outer layer on it. It's easy to cut, and I left the four main pieces loose (glued the tunnel pieces onto the carpet) in case it ever gets wet again, so I can quickly pull the padding out without having to completely remove the carpet. Link to comment Share on other sites More sharing options...
nick1208 Posted May 16, 2014 Author Share Posted May 16, 2014 On 5/16/2014 at 3:45 PM, SmashedGlass said: I'd pull it, Nick. Unless you live somewhere completely arid, like Arizona-Nevada-SoCal, the padding will never dry out. It isn't that hard (except getting it from behind the blower motor housing--I cut mine to alleviate that problem), and you'll be able to salvage the carpet itself. As to the padding, I replaced mine with some Ultratouch Radiant Barrier that I picked up at Home Depot, it's like the jute padding but has an aluminized outer layer on it. It's easy to cut, and I left the four main pieces loose (glued the tunnel pieces onto the carpet) in case it ever gets wet again, so I can quickly pull the padding out without having to completely remove the carpet. So you cut the carpet into pieces to make it easy to put in and out? That seems like a cool idea. Does the trunk carpet connect to the carpet for the rest of the car? Marcus said It comes out in one piece. What's the easiest way to pull the carpet? It feels dry but when i put pressure on it I can feel the moisture. 1 Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 16, 2014 Share Posted May 16, 2014 Don't cut it to pieces.. Pull front seats and no the rear isn't connected to the front.. But can be removed also... Link to comment Share on other sites More sharing options...
Subruise Posted May 17, 2014 Share Posted May 17, 2014 my hatchy is dry inside, and i live near Nick. I had 3 inches of water in it. I pulled back the carpet and vacuumed the bottom, several times but it worked. Its a lot of work but it can be done 1 Link to comment Share on other sites More sharing options...
nick1208 Posted May 19, 2014 Author Share Posted May 19, 2014 finally decided to get rid of my carpets. it was wet underneath on the passenger side which I haven't sunk in water (or so i thought). That might be where the smell I couldn't source was coming from. What's the material under the carpets and padding made of? on top of the metal? It's cracking in some spots and I peeled a bit off. Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 19, 2014 Share Posted May 19, 2014 (edited) Stop by my place and grab a can of spray on bed liner and paint the floor...the material is a tar type sound deadener..leave it alone unless your doing a resto cuz without it the road noise will drive you crazy. Its on theback yard Edited May 19, 2014 by marcusgl10z28 Link to comment Share on other sites More sharing options...
nick1208 Posted May 19, 2014 Author Share Posted May 19, 2014 On 5/19/2014 at 5:06 AM, marcusgl10z28 said: Stop by my place and grab a can of spray on bed liner and paint the floor...the material is a tar type sound deadener..leave it alone unless your doing a resto cuz without it the road noise will drive you crazy. Its on theback yard Should I worry about getting the dried mud up? I didn't know how to go about that. I didn't want to hose it down Link to comment Share on other sites More sharing options...
bratman18 Posted May 19, 2014 Share Posted May 19, 2014 I've run no carpet in a few of my rigs because of them getting wet and holding moisture. The road noise isn't that bad. 1 Link to comment Share on other sites More sharing options...
kirzick Posted May 19, 2014 Share Posted May 19, 2014 Did you leave your sway bars on? Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 19, 2014 Share Posted May 19, 2014 (edited) I don't mean the carpet or insulation that's under the carpet.. I mean the tar that coats the floor boards.. Its sound deadener.. Leave it alone nick... Clean up the mud best you can with a wet rag and soap.. Its gonna take a little while just work 1 foot well at a time.. The paint it all. Dry vacuum what's loose and what you canbreak loose with a brush Edited May 19, 2014 by marcusgl10z28 1 Link to comment Share on other sites More sharing options...
nick1208 Posted May 19, 2014 Author Share Posted May 19, 2014 I'll get on it once I finish up this water pump leak/ Link to comment Share on other sites More sharing options...
NorthCoast Posted May 19, 2014 Share Posted May 19, 2014 (edited) Wet rag and soap? He didn't shart in his car, just got a little muddy. Don't worry about the mud 'cause you're bound to get more. It vacuums right up once it's dry anyway. That sound deadening stuff is just extra weight. Almost forgot... I've got those lamps and clip for you at the house. Edited May 19, 2014 by NorthCoast 1 Link to comment Share on other sites More sharing options...
NorthCoast Posted May 19, 2014 Share Posted May 19, 2014 On 5/2/2014 at 6:24 AM, ystrdyisgone said: There is another option you know.. Take the car to school, and tell the people who wanna use you for your car to F off.. or phrase it however you would like to get the point across. or just put this sticker on... 2 Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 19, 2014 Share Posted May 19, 2014 On 5/19/2014 at 7:19 PM, NorthCoast said: or just put this sticker on... I'm getting one for all my rides.. 1 Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 20, 2014 Share Posted May 20, 2014 On 5/19/2014 at 4:20 AM, nick1208 said: finally decided to get rid of my carpets. it was wet underneath on the passenger side which I haven't sunk in water (or so i thought). That might be where the smell I couldn't source was coming from. What's the material under the carpets and padding made of? on top of the metal? It's cracking in some spots and I peeled a bit off. those floor boards are way to straight nick... it looks like a new car...lol Link to comment Share on other sites More sharing options...
