nick1208 Posted April 6, 2015 Author Share Posted April 6, 2015 this would explain why my high-beam dash indicator doesnt work anymore.... Also my drivers side door always says its open when its not...maybe i shouldnt sink my car underwater so often Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 6, 2015 Share Posted April 6, 2015 On 4/5/2015 at 6:39 AM, Loyale 2.7 Turbo said: Thank you for your Kind Words, Here's the Link: ~► http://www.ultimatesubaru.org/forum/topic/87523-how-to-swap-the-old-roundie-relays-with-standard-bosch-relays/ I hope this can help. Kind Regards. On 4/4/2015 at 11:54 PM, Subruise said: relays. Jezsek has a great write up. saved me On 4/6/2015 at 8:00 PM, marcusgl10z28 said: One heck of a great writeup jeszek!!! Very nice On 4/6/2015 at 8:03 PM, NorthCoast said: you mean... On 4/6/2015 at 8:06 PM, marcusgl10z28 said: ^ pretty much sums it up!^^ Wow! ... ... Thank you so Much! 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 6, 2015 Share Posted April 6, 2015 On 4/6/2015 at 10:53 PM, nick1208 said: this would explain why my high-beam dash indicator doesnt work anymore... Yes. On 4/6/2015 at 10:53 PM, nick1208 said: ...Also my drivers side door always says its open when its not... You only need to do an small adjustment to the Door's latch on the Subie's Body, to let it close Tighter... Kind Regards. Link to comment Share on other sites More sharing options...
nick1208 Posted June 23, 2015 Author Share Posted June 23, 2015 Home from school and trying to daily the wagon, the small issues are making it tough. went through and replaced both front struts so my camber issue is fixed. also got the ford tempo front springs so it sits less raked and more level. Passed the car off to Rob so he can chase a coolant leak and replace my leaking fuel tank from WCSS last year. here is an updated pic with a fresh wash and GC grill i update instagram more often: @subaruloyale cheers 1 Link to comment Share on other sites More sharing options...
Subruise Posted June 23, 2015 Share Posted June 23, 2015 next time try to clear the jumps instead of tag on all of em =D Link to comment Share on other sites More sharing options...
nick1208 Posted June 23, 2015 Author Share Posted June 23, 2015 On 6/23/2015 at 6:46 AM, Subruise said: next time try to clear the jumps instead of tag on all of em =D Would have gone harder but I needed to drive it home. Need a flat bed if im going to do that again Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 24, 2015 Share Posted June 24, 2015 On 6/23/2015 at 5:13 AM, nick1208 said: ... replaced both front struts so my camber issue is fixed. also got the ford tempo front springs so it sits less raked and more level... How do you feel the Front suspension with the Tempo coil Springs? I have many years using those on my "BumbleBeast" See ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ Kind Regards. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted June 25, 2015 Author Share Posted June 25, 2015 On 6/24/2015 at 2:00 PM, Loyale 2.7 Turbo said: How do you feel the Front suspension with the Tempo coil Springs? I have many years using those on my "BumbleBeast" See ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ Kind Regards. I really enjoy the ride. I can see that it sits higher in the front which is nice because before my car was really raked in the back from the honda springs. It rides smooth as well. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 25, 2015 Share Posted June 25, 2015 On 6/25/2015 at 1:47 AM, nick1208 said: I really enjoy the ride. I can see that it sits higher in the front which is nice because before my car was really raked in the back from the honda springs. It rides smooth as well. Yes, the Honda Accord coil Springs in the Rear + Ford Tempo coil Springs in the Front is the Best Combo, due to the equality of the Suspension's Stiffness in both axles, and provides better Handling than the Stock one, despite of being Harder. Thank you for your feedback. Kind Regards. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted July 9, 2015 Author Share Posted July 9, 2015 came home with the donor car today...almost want to just keep it as a daily. 1996 subaru legacy L 5 spd ej22 246k miles Phase 2 runs & drives great. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted July 12, 2015 Author Share Posted July 12, 2015 Link to comment Share on other sites More sharing options...
nick1208 Posted July 26, 2015 Author Share Posted July 26, 2015 My old clutch, pretty toast. Redrilled the flywheel. drill press worked just fine Engine in! hopefully more progress this week. 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 28, 2015 Share Posted July 28, 2015 On 7/26/2015 at 11:49 PM, nick1208 said: ...Engine in! hopefully more progress this week. Looking Good! The SJR lift block has the letters facing to front, I guess it is because is a 4" Lift? On my "BumbleBeast" the SJR letters are towards outside of the Fender... But those are 2" blocks only; Kind Regards. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 28, 2015 Share Posted July 28, 2015 The SJR lift block has the letters facing to front, I guess it is because is a 4" Lift? On my "BumbleBeast" the SJR letters are towards outside of the Fender... Style has changed over the years your both correct 1 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 28, 2015 Share Posted July 28, 2015 On 7/28/2015 at 6:49 PM, Scott in Bellingham said: ... Style has changed over the years your both correct Thank you for clarifying! Link to comment Share on other sites More sharing options...
NorthCoast Posted August 4, 2015 Share Posted August 4, 2015 I know it's running. Where's the update? Link to comment Share on other sites More sharing options...
nick1208 Posted August 4, 2015 Author Share Posted August 4, 2015 Runs, seems to smoke out the passenger side exhaust, where the header gets bolted on...Not sure why...oil dripping out down the headers too......smells pretty bad. It's having a hard time cooling as well. fans arent kicking on. Link to comment Share on other sites More sharing options...
Prwa101 Posted August 4, 2015 Share Posted August 4, 2015 The fans need to be on a relay controlled by the ECU Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 4, 2015 Share Posted August 4, 2015 You need to run it to burn the oil off. I got the atf in my exhaust/on and it smoked for quite awhile. My fans are hooked up like original on mine. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted August 4, 2015 Author Share Posted August 4, 2015 On 8/4/2015 at 5:14 PM, Prwa101 said: The fans need to be on a relay controlled by the ECU i hooked them up to the stock fan plugs in the ECU. hopefully they turn on now. I want to test it but have no way of telling if it is overheating except common sense. Link to comment Share on other sites More sharing options...
nick1208 Posted August 5, 2015 Author Share Posted August 5, 2015 (edited) super frustrated by it not shutting off with my key and having to pull the connection on the battery...Can't find what the problem could be. Also fan is not turning on when it gets hot....which is another thing that bugs me. Edited August 5, 2015 by nick1208 Link to comment Share on other sites More sharing options...
Prwa101 Posted August 5, 2015 Share Posted August 5, 2015 hahah make sure the mention now awesome i am Nick Link to comment Share on other sites More sharing options...
nick1208 Posted August 5, 2015 Author Share Posted August 5, 2015 Patrick helped me sort out the situation where it wouldn't turn off with my key! big thanks to him, skyping with me walking me through it in his free time. Temporarily wired my fan to a switch, going to try to take it out tomorrow. Link to comment Share on other sites More sharing options...
nick1208 Posted October 28, 2015 Author Share Posted October 28, 2015 Can't believe I sold it! This car is no longer mine if you want to follow the build more here is his instagram:https://instagram.com/crumley6969/It was a pretty good run I had with this beast. I enjoy the time I spent building it and fixing it. Especially the people I met through owning this car. I have another old school lined up to buy so keep your eye out for a new post by me in "members rides" this weekend. 1 Link to comment Share on other sites More sharing options...
jsyme Posted July 5, 2017 Share Posted July 5, 2017 I watched the whole time line and I'm sad there was only 7 pictures of the car after it was sold. Link to comment Share on other sites More sharing options...
