Hello everyone. I have a 2001 Forester that I would like to build a EJ22T hybrid for it. I have a friend that has a hybrid EJ22T in his 91 legacy and I am fairly impressed with it. I already bought a complete EJ22T engine from intake to cat. What I was thinking was using a 2.5 crank (not sure if I can) the 2.2 rods, bore the cylinders for 2.5 pistons, phase 1 2.5 sohc heads with the cams reground for proper throw and duration to maintain non interference. Arp head studs, a good gasket set (tbd) sti intake manifold phase 1, aftermarket header, down pipe and muffler. Tdo5-20g turbo and and finally a 2.5x ECU. Please let me know if there is anything that will not work and why. Thank you for your time, it is much appreciated.
  • Like 1
