JC20 Posted December 20, 2013 Share Posted December 20, 2013 I was under the impression that the Aisin water pump was the oem for EJ22, but I have also heard paraut was used by Subaru.I found these two on Amazon, and I was wondering which one I Should buy? There also a big price difference, and I'm not really sure why. http://www.amazon.com/gp/product/B008EEYXIO/ref=s9_simh_gw_p263_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=12FE1J23701QPGW59JWE&pf_rd_t=101&pf_rd_p=1630083462&pf_rd_i=507846 and http://www.amazon.com/dp/B001G6AZZC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=E4G8D74WIAPO&coliid=I157CWO36TMWSS Link to comment Share on other sites More sharing options...
MilesFox Posted December 20, 2013 Share Posted December 20, 2013 (edited) The aisin one has the fuji stamp on it, s that would make me assume it is a rebuild, Perhaps the paraut one is new aftermarket. Edited December 20, 2013 by MilesFox Link to comment Share on other sites More sharing options...
1badmkIrocco Posted December 29, 2013 Share Posted December 29, 2013 I was under the impression that the Aisin water pump was the oem for EJ22, but I have also heard paraut was used by Subaru.I found these two on Amazon, and I was wondering which one I Should buy? There also a big price difference, and I'm not really sure why. http://www.amazon.com/gp/product/B008EEYXIO/ref=s9_simh_gw_p263_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=12FE1J23701QPGW59JWE&pf_rd_t=101&pf_rd_p=1630083462&pf_rd_i=507846 and http://www.amazon.com/dp/B001G6AZZC/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=E4G8D74WIAPO&coliid=I157CWO36TMWSS I just did a Waterpump and Timing Belt on my EJ22 Legacy and the pump that was ON the car was a Parut. I had purchased the AISIN as a replacemet based on recommendations I found on here and the fact it was made in Japan. When I pulled the Parut I noticed that the impeller on the pump was completely different than the Aisin. The Aisin impeller was a stamped piece while the Parut was a cast piece of completely different design (what you see in the picture), but the Aisin shipped with a completely different design. That's not to say the Aisin is any better or worse, but it's obvious that the newest design is a cheaper one. My confidence was also broken when my co-worker's Toyota 4runner suffered catastrophic bearing failure in his water pump which was an Aisin branded unit from Napa after just under 40K miles. This is what's on the Aisin now compared to the old: Link to comment Share on other sites More sharing options...
monstaru Posted December 29, 2013 Share Posted December 29, 2013 I have rarely heard of a water pump failure on any Roo around. Especially EJ22. If you are into your car at all you will notice warning signs before any type of failure. I have installed both, had good luck with both. cheers Link to comment Share on other sites More sharing options...
