bettyspagetti Posted May 18, 2014 Share Posted May 18, 2014 hello all i have just fixed my mums car with this exact problem but i probably tested and changed out more parts than you have... what it was in the end up above the fuse panel on the drivers side is a brown 6 pin relay that open circuits when faulty and cuts injector pulse under load it would do it uphill in exactly the same spot every time... how weird.... look for a brown relay it is right up near the windscreen pt no is 25232aa000 you can buy it on ebay hope this helps every one as a lot of people have the same problem when you google it good luck brett Link to comment Share on other sites More sharing options...
