shortlid Posted December 29, 2013 Share Posted December 29, 2013 (edited) OK, want to do a drain and refill with 50/50 distilled water and correct coolant. Should I use good old green stuff low silicate, organic non-silicate coolant, or the exspensive Subaru Long life in my '03 GT with EJ253? Looks like the new Blue stuff was in 2009 + Roos only? Edited December 29, 2013 by shortlid Quote Link to comment Share on other sites More sharing options...
afterbang Posted December 30, 2013 Share Posted December 30, 2013 Subaru long life coolant is the normal green stuff, but it supposedly has a different formulation. The "super coolant" is the blue stuff and it's not spec'd for use in your car. Just use the normal green stuff from any auto supply store and save yourself the money. Working on Subarus most days at work, I've never seen the supposed gelling that the long life claims to protect against, even on the most neglected of cars. I bought my wife an 03 Legacy, which was always dealer serviced and had the long life in it. When I did the t-belt job on it, I just used a 50/50 mix of the normal stuff. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 30, 2013 Share Posted December 30, 2013 The Subaru long life stuff I've been buying for the past couple years is blue-green color. I've used both Subaru stuff and plain old green. Haven't noticed any ill effects from the plain green, but you HAVE to remember to change it every 2 years. Quote Link to comment Share on other sites More sharing options...
mikec03 Posted December 30, 2013 Share Posted December 30, 2013 I believe there is a problem with the "any green" is OK. The Subaru Long Life, which is green, is advertised as silicone and phosporus free. However if you look at Peak Conventional Green, it specifically includes silicone and phosporus. Some posters have said that the Peak Long Life in the blue bottle is the proper match for the Subaru Long Life [white bottle]. For the record, the following antifreezes are sold by Peak Global Lifetime [OAT, P & S free, Gold bottle]; Long Life [P & S free, Blue bottle, no mention of OAT]; Conventional Green ["patented Aluminium Protection" containing S and P, Blue bottle];Cool [Dex-Cool equivilent, Gray bottle]. By the way, I'm using the Peak Conventional Green in my two 90's subarus and the Subaru Long Life in my 02 subaru. I have no idea if this is the proper thing to do. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 30, 2013 Share Posted December 30, 2013 (edited) The Subaru long life stuff I've been buying for the past couple years is blue-green color. I've used both Subaru stuff and plain old green. Haven't noticed any ill effects from the plain green, but you HAVE to remember to change it every 2 years. An easy way to stretch the plain old green antifreeze another 2 years is to add a container of water pump lubricant additive each Fall to the cooling system, after the first two years. The additive replaces the anti-rust property of the plain old green antifreeze, which wears out over time. My dad, who owned a gas station, taught me this trick some 40+ years ago. Sure saves time, and beats the mess of changing antifreeze every 2 years. Edited December 30, 2013 by Rooster2 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 30, 2013 Share Posted December 30, 2013 The concern with the plain greem stuff is not so much with the anti-corrosive properties. It's that over time the additives that prevent corrosion and rust, and maintain freeze protection, will settle out of the coolant. They drop to the bottom of the system and collect and solidify into hard chunky stuff that can then float around and clog the heater core and radiator. It can also wear the impeller of the water pump, kinda like sand blasting. Quote Link to comment Share on other sites More sharing options...
shortlid Posted December 31, 2013 Author Share Posted December 31, 2013 Ok so Peak Long life is the stuff to get. Thanks Quote Link to comment Share on other sites More sharing options...
