Not sure where your box is located on that model, but try looking between the passenger side shock tower and firewall. If you see a silver rectangular box that says "CAUTION-HOT", there will be a connector plug to it. All you need to do is disconnect this to disable the DRL.
If its not there it will be inside the car behind the glove box. You will prob need to remove the glove box to get to it.
Same thing applies tho, just unplug it.
Oh man. Rob is the closest on this.
Peek under the dash by the steering column. There should be a box with two plugs going into it, a black one and a white one. The side should say something along the lines of DRL system or Day Time Running Light Control, I can't quite remember. One of the two connectors needs to be unplugged for them to be disabled. Did this on my '04 Outback
  • Like 1
  On 12/31/2013 at 3:02 PM, CNY_Dave said:
I thought the hot metal item was the transmission dropping resistor...
There's a DRL thread on site somewhere, a quick search will turn it up.
 Tried to search to DRL nothing came up?
You were correct on my '03 just unplug the white connector to the black box next to the steering shaft!  Easy peasy!
